I am trying to gather data from my wall panel
my wall panel is loading hab panel through the wall panel android app
but I am having trouble getting it to read the Mqtt
I am not great at Json stuff yet
so one payload type is
{“value”:false}
this is for a motion contact
and this other one I want to break out into a few items
{“charging”:true,“value”:100,“acPlugged”:true,“unit”:"%",“usbPlugged”:false}
with Json I have done this with Tasmota devices but for some reason
I just can’t get the format right
The JSONPATH transform is installed?
Errors in the log?
You’ve confirmed the message are being sent with something like MQTT.fx or MQTt Explorer?
The Bridge Thing is Online?
It really helps a whole lot to not withhold important information like what you’ve tried, errors you are seeing in the logs, etc. All we know is what you tell us and we end up needing to play 20 questions which wastes everyone’s time.
Yes, you don’t need to transform that if it’s always just as you see there.
yes Json has been installed I have used it with several other devices
I will check the logs I am sure its something I am doing wrong
yeah I have Mqttfx open and I have confrimed the messages
I have been copying the actual messages from mqttFx to this thread I generally don’t add any Mqtt items with out confirming messages and syntax this way
its Fixed I clearly was typing something wrong
I deleted the whole channel and started over works now
not 100% sure what mistake I was making repeatedly
but its fixed
thanks rlkoshak for confirming for me what I thought
