Max77
(Max)
October 29, 2020, 11:35pm
1
Hi all!
I am trying to implement a generic MQTT thing, and I need to part a Json string. Unfortunately Jsonpath transformation are not my strength
The item is defined as follow
String mqttEspNowTestVal2 “Val Test ESPNow [JSONPATH($.device.status.temperature):%s °C]” {channel=“mqtt:topic:54e1b26f:XX-XowTestESPnow”}
To make it the simplest possible, I programmed the remote sender to send the string as provided here
2020-10-30 00:17:59.640 [vent.ItemStateChangedEvent] - mqttEspNowTestVal2 changed from {“device_id”:50:02:91:DC:DC:8F, “value”:81} to [{ “device”: { “location”: “Outside”, “status”: { “temperature”: 23.2 }}}]
Still, the log contains the error
2020-10-30 00:28:27.060 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state '[{ "device": { "location": "Outside", "status": { "temperature": 23.2 }}}]' on item 'mqttEspNowTestVal2' with pattern 'JSONPATH($.device.status.temperature):%s °C': Invalid path '$.device.status.temperature' in '[{ "device": { "location": "Outside", "status": { "temperature": 23.2 }}}] °C'
I am sure I am missing something trivial, but I am out of ideas…
Thanks!
Max
rossko57
(Rossko57)
October 30, 2020, 1:36am
2
It’s the square brackets that you have added, turning your JSON into a one-element array
val rawjson = '[{ "device": { "location": "Outside", "status": { "temperature": 23.2 }}}]'
var results = transform("JSONPATH", "$.device.status.temperature", rawjson)
logInfo("test", " simple path " + results)
results = transform("JSONPATH", "$[0].device.status.temperature", rawjson)
logInfo("test", " array path " + results)
2020-10-30 01:33:25.154 [INFO ] [.eclipse.smarthome.model.script.test] - simple path [{ "device": { "location": "Outside", "status": { "temperature": 23.2 }}}]
2020-10-30 01:33:25.156 [INFO ] [.eclipse.smarthome.model.script.test] - array path 23.2
Max77
(Max)
October 30, 2020, 8:33pm
3
Thanks @rossko57 !
I have now implemented the complete item with the JSONPATH transformation
String mqttEspNowTestVal "Val Test ESPNow" {channel="mqtt:topic:54e1b26f:XX-XowTestESPnow"[profile="transform:JSONPATH", function="$.value"]}
This works as long as the item is defined as String - am I right to say that w/o a rule (like this ) I cannot have the item value stored as Number ?
If yes, anything going to be different when looking forwards to OH3?
Thanks again!
Max
P.S.: another good JSONPATH validator here
rossko57
(Rossko57)
October 30, 2020, 10:31pm
4
Yes, at OH2 the transform profile is limited to use with String type Items.
More usefully versatile in OH3, I am told.
But …
Why aren’t you using the transform feature built into the MQTT channel, allowing you to output directly to any Item type? That’s what its for.
Treat all JSONPATH online validators with a little caution, the openHAB JSONPATH Transformation Service is not JSONPATH, there are differences in places.
Max77
(Max)
October 31, 2020, 8:30am
5
Hi @rossko57
I guess you mean the incoming transformation in the thing definition. I completely missed that, I will give a try and likely post another question
Max
