Ok, here are the detailed information.
Hardware = Desktop-PC with AMD Phenom II X4 CPU, 16GB RAM
OS = Ubuntu 16.04.01 64 bit
Java = java version “1.8.0_101” / Java™ SE Runtime Environment (build 1.8.0_101-b13)
OH version is as mentioned above 1.8.3
As this is my test system, I removed everything (bindings, rules, items, …) except the milight related parts.
Then started OH and did exactly the same
- Turned on switch for milight strip controler -> Switch Light_Party2 (gMilight) {milight=“bridge1;5”}
- Turned off switch
- Turned on switch again
- Changed color with Colorpicker item -> Color Light_Party (gMilight) {milight=“bridge1;5;rgb”}
- Changed brightness with Colorpicker item
Here is the debug log with 1.7.1 binding (everythings works fine)
18:07:00.637 [DEBUG] [.s.internal.SchedulerActivator:36 ] - Scheduler has been started.
18:07:00.670 [INFO ] [uartz.impl.StdSchedulerFactory:1175 ] - Using default implementation for ThreadExecutor
18:07:00.686 [INFO ] [rtz.core.SchedulerSignalerImpl:61 ] - Initialized Scheduler Signaller of type: class org.quartz.core.SchedulerSignalerImpl
18:07:00.687 [INFO ] [rg.quartz.core.QuartzScheduler:243 ] - Quartz Scheduler v.2.1.7 created.
18:07:00.688 [INFO ] [org.quartz.simpl.RAMJobStore :154 ] - RAMJobStore initialized.
18:07:00.689 [INFO ] [rg.quartz.core.QuartzScheduler:268 ] - Scheduler meta-data: Quartz Scheduler (v2.1.7) 'openHAB-job-scheduler' with instanceId 'NON_CLUSTERED'
Scheduler class: 'org.quartz.core.QuartzScheduler' - running locally.
NOT STARTED.
Currently in standby mode.
Number of jobs executed: 0
Using thread pool 'org.quartz.simpl.SimpleThreadPool' - with 2 threads.
Using job-store 'org.quartz.simpl.RAMJobStore' - which does not support persistence. and is not clustered.
18:07:00.690 [INFO ] [uartz.impl.StdSchedulerFactory:1324 ] - Quartz scheduler 'openHAB-job-scheduler' initialized from specified file: './etc/quartz.properties'
18:07:00.690 [INFO ] [uartz.impl.StdSchedulerFactory:1328 ] - Quartz scheduler version: 2.1.7
18:07:00.690 [INFO ] [rg.quartz.core.QuartzScheduler:534 ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
18:07:00.693 [DEBUG] [o.config.core.ConfigDispatcher:146 ] - Processing openHAB default configuration file '/opt/openhab/openhab/configurations/openhab_default.cfg'.
18:07:00.955 [DEBUG] [o.config.core.ConfigDispatcher:168 ] - Processing openHAB main configuration file '/opt/openhab/openhab/configurations/openhab.cfg'.
18:07:01.182 [DEBUG] [.o.core.internal.CoreActivator:93 ] - UUID file already exists at '/opt/openhab/openhab/webapps/static/uuid' with content '53e6ce57-3afb-4ea7-93f2-7685a83c16be'
18:07:01.183 [DEBUG] [.o.core.internal.CoreActivator:115 ] - Created file '/opt/openhab/openhab/webapps/static/version' with content '1.8.3'
18:07:01.184 [INFO ] [.o.core.internal.CoreActivator:61 ] - openHAB runtime has been started (v1.8.3).
18:07:01.206 [DEBUG] [a.internal.AutoUpdateActivator:31 ] - AutoUpdate binding has been started.
18:07:01.944 [DEBUG] [.p.i.PersistenceModelActivator:23 ] - Registered 'persistence' configuration parser
18:07:01.962 [DEBUG] [.c.t.i.TransformationActivator:38 ] - Transformation Service has been started.
18:07:02.007 [DEBUG] [m.internal.MultimediaActivator:34 ] - Multimedia I/O bundle has been started.
18:07:02.046 [DEBUG] [.s.i.DiscoveryServiceActivator:27 ] - Discovery service has been started.
18:07:02.057 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:93 ] - mDNS service has been started
18:07:02.100 [DEBUG] [.io.transport.mqtt.MqttService:123 ] - Starting MQTT Service...
18:07:02.122 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:53 ] - Service Discovery initialization completed.
18:07:02.215 [DEBUG] [.i.internal.ItemModelActivator:24 ] - Registered 'item' configuration parser
18:07:02.322 [DEBUG] [o.o.c.i.items.ItemRegistryImpl:137 ] - Item provider 'GenericItemProvider' has been added.
18:07:03.032 [DEBUG] [.o.m.s.i.SitemapModelActivator:23 ] - Registered 'sitemap' configuration parser
18:07:03.096 [DEBUG] [io.rest.internal.RESTActivator:33 ] - REST API has been started.
18:07:04.160 [INFO ] [penhab.io.rest.RESTApplication:144 ] - Started REST API at /rest
18:07:04.161 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66 ] - Registering new service _openhab-server._tcp.local. at port 8080
18:07:09.862 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66 ] - Registering new service _openhab-server-ssl._tcp.local. at port 8443
18:07:11.734 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'default.sitemap'
18:07:11.922 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'test.items'
18:07:11.955 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'test.items'
18:07:11.960 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'test.items'
18:07:12.534 [INFO ] [.o.u.w.i.servlet.WebAppServlet:80 ] - Started Classic UI at /classicui/openhab.app
18:07:12.845 [DEBUG] [.r.internal.RuleModelActivator:42 ] - Registered 'rules' configuration parser
18:07:12.856 [DEBUG] [m.r.internal.engine.RuleEngine:77 ] - Started rule engine
18:07:15.376 [DEBUG] [.b.m.internal.MilightActivator:34 ] - Milight binding has been started.
18:07:15.385 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Light_Party2 (Type=SwitchItem, State=Uninitialized)' with 'MilightGenericBindingProvider' reader.
18:07:15.386 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Light_Party (Type=ColorItem, State=Uninitialized)' with 'MilightGenericBindingProvider' reader.
18:07:15.387 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'DiscoMode (Type=DimmerItem, State=Uninitialized)' with 'MilightGenericBindingProvider' reader.
18:07:15.387 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'DiscoSpeed (Type=DimmerItem, State=Uninitialized)' with 'MilightGenericBindingProvider' reader.
18:07:22.008 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'test.rules'
18:07:58.119 [DEBUG] [.o.b.m.internal.MilightBinding:96 ] - milight: item is of type brightness
18:07:58.120 [DEBUG] [.o.b.m.internal.MilightBinding:608 ] - milight: sendOn
18:07:58.120 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '22:00:55'
18:07:58.121 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '22:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:22.150 [DEBUG] [.o.b.m.internal.MilightBinding:96 ] - milight: item is of type brightness
18:08:22.151 [DEBUG] [.o.b.m.internal.MilightBinding:660 ] - milight: sendOff
18:08:22.151 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '21:00:55'
18:08:22.151 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '21:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:40.364 [DEBUG] [.o.b.m.internal.MilightBinding:96 ] - milight: item is of type brightness
18:08:40.364 [DEBUG] [.o.b.m.internal.MilightBinding:608 ] - milight: sendOn
18:08:40.364 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '22:00:55'
18:08:40.365 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '22:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:52.459 [DEBUG] [.o.b.m.internal.MilightBinding:178 ] - milight: item is of type rgb
18:08:52.459 [DEBUG] [.o.b.m.internal.MilightBinding:721 ] - milight: sendColor
18:08:52.459 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '20:5c:55'
18:08:52.460 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '20:5c:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:52.460 [DEBUG] [.o.b.m.internal.MilightBinding:192 ] - milight: sendPercent
18:08:52.460 [DEBUG] [.o.b.m.internal.MilightBinding:608 ] - milight: sendOn
18:08:52.461 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '22:00:55'
18:08:52.461 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '22:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:52.561 [DEBUG] [.o.b.m.internal.MilightBinding:304 ] - milight: sendIncrease
18:08:52.562 [DEBUG] [.o.b.m.internal.MilightBinding:608 ] - milight: sendOn
18:08:52.562 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '22:00:55'
18:08:52.562 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '22:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:52.663 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '23:00:55'
18:08:52.664 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '23:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:52.764 [DEBUG] [.o.b.m.internal.MilightBinding:304 ] - milight: sendIncrease
18:08:52.765 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '23:00:55'
18:08:52.765 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '23:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:52.866 [DEBUG] [.o.b.m.internal.MilightBinding:304 ] - milight: sendIncrease
18:08:52.866 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '23:00:55'
18:08:52.867 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '23:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:52.967 [DEBUG] [.o.b.m.internal.MilightBinding:304 ] - milight: sendIncrease
18:08:52.968 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '23:00:55'
18:08:52.968 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '23:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:53.069 [DEBUG] [.o.b.m.internal.MilightBinding:304 ] - milight: sendIncrease
18:08:53.070 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '23:00:55'
18:08:53.070 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '23:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:53.170 [DEBUG] [.o.b.m.internal.MilightBinding:304 ] - milight: sendIncrease
18:08:53.171 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '23:00:55'
18:08:53.172 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '23:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:53.272 [DEBUG] [.o.b.m.internal.MilightBinding:304 ] - milight: sendIncrease
18:08:53.273 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '23:00:55'
18:08:53.273 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '23:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:53.374 [DEBUG] [.o.b.m.internal.MilightBinding:304 ] - milight: sendIncrease
18:08:53.374 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '23:00:55'
18:08:53.375 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '23:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:53.475 [DEBUG] [.o.b.m.internal.MilightBinding:304 ] - milight: sendIncrease
18:08:53.476 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '23:00:55'
18:08:53.476 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '23:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:08:53.577 [DEBUG] [.o.b.m.internal.MilightBinding:304 ] - milight: sendIncrease
18:08:53.578 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '23:00:55'
18:08:53.579 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '23:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:09:11.569 [DEBUG] [.o.b.m.internal.MilightBinding:178 ] - milight: item is of type rgb
18:09:11.569 [DEBUG] [.o.b.m.internal.MilightBinding:721 ] - milight: sendColor
18:09:11.569 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '20:5c:55'
18:09:11.570 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '20:5c:55' to bridge 'bridge1' (192.168.178.40:8899)
18:09:11.570 [DEBUG] [.o.b.m.internal.MilightBinding:192 ] - milight: sendPercent
18:09:11.570 [DEBUG] [.o.b.m.internal.MilightBinding:608 ] - milight: sendOn
18:09:11.571 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '22:00:55'
18:09:11.571 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '22:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:09:11.672 [DEBUG] [.o.b.m.internal.MilightBinding:348 ] - milight: sendDecrease
18:09:11.672 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '24:00:55'
18:09:11.673 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '24:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:09:11.773 [DEBUG] [.o.b.m.internal.MilightBinding:348 ] - milight: sendDecrease
18:09:11.774 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '24:00:55'
18:09:11.777 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '24:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:09:11.878 [DEBUG] [.o.b.m.internal.MilightBinding:348 ] - milight: sendDecrease
18:09:11.878 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '24:00:55'
18:09:11.879 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '24:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:09:11.979 [DEBUG] [.o.b.m.internal.MilightBinding:348 ] - milight: sendDecrease
18:09:11.980 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '24:00:55'
18:09:11.981 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '24:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:09:12.081 [DEBUG] [.o.b.m.internal.MilightBinding:348 ] - milight: sendDecrease
18:09:12.082 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '24:00:55'
18:09:12.082 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '24:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:09:12.183 [DEBUG] [.o.b.m.internal.MilightBinding:348 ] - milight: sendDecrease
18:09:12.183 [DEBUG] [.o.b.m.internal.MilightBinding:780 ] - milight: messageBytes to transform: '24:00:55'
18:09:12.184 [DEBUG] [.o.b.m.internal.MilightBinding:771 ] - Sent packet '24:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:09:29.232 [INFO ] [penhab.io.rest.RESTApplication:160 ] - Stopped REST API
18:09:29.232 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:80 ] - Unregistering service _openhab-server._tcp.local. at port 8080
18:09:31.235 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:80 ] - Unregistering service _openhab-server-ssl._tcp.local. at port 8443
And this is the log for 1.8.3 binding (switch and colorchange are ok, but no brightness change)
18:13:14.823 [DEBUG] [.s.internal.SchedulerActivator:36 ] - Scheduler has been started.
18:13:14.855 [INFO ] [uartz.impl.StdSchedulerFactory:1175 ] - Using default implementation for ThreadExecutor
18:13:14.872 [INFO ] [rtz.core.SchedulerSignalerImpl:61 ] - Initialized Scheduler Signaller of type: class org.quartz.core.SchedulerSignalerImpl
18:13:14.872 [INFO ] [rg.quartz.core.QuartzScheduler:243 ] - Quartz Scheduler v.2.1.7 created.
18:13:14.873 [INFO ] [org.quartz.simpl.RAMJobStore :154 ] - RAMJobStore initialized.
18:13:14.874 [INFO ] [rg.quartz.core.QuartzScheduler:268 ] - Scheduler meta-data: Quartz Scheduler (v2.1.7) 'openHAB-job-scheduler' with instanceId 'NON_CLUSTERED'
NOT STARTED.
18:13:14.875 [INFO ] [uartz.impl.StdSchedulerFactory:1324 ] - Quartz scheduler 'openHAB-job-scheduler' initialized from specified file: './etc/quartz.properties'
18:13:14.875 [INFO ] [uartz.impl.StdSchedulerFactory:1328 ] - Quartz scheduler version: 2.1.7
18:13:14.875 [INFO ] [rg.quartz.core.QuartzScheduler:534 ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
18:13:14.878 [DEBUG] [o.config.core.ConfigDispatcher:146 ] - Processing openHAB default configuration file '/opt/openhab/openhab/configurations/openhab_default.cfg'.
18:13:15.136 [DEBUG] [o.config.core.ConfigDispatcher:168 ] - Processing openHAB main configuration file '/opt/openhab/openhab/configurations/openhab.cfg'.
18:13:15.376 [DEBUG] [.o.core.internal.CoreActivator:93 ] - UUID file already exists at '/opt/openhab/openhab/webapps/static/uuid' with content '53e6ce57-3afb-4ea7-93f2-7685a83c16be'
18:13:15.377 [DEBUG] [.o.core.internal.CoreActivator:115 ] - Created file '/opt/openhab/openhab/webapps/static/version' with content '1.8.3'
18:13:15.378 [INFO ] [.o.core.internal.CoreActivator:61 ] - openHAB runtime has been started (v1.8.3).
18:13:15.398 [DEBUG] [a.internal.AutoUpdateActivator:31 ] - AutoUpdate binding has been started.
18:13:16.136 [DEBUG] [.p.i.PersistenceModelActivator:23 ] - Registered 'persistence' configuration parser
18:13:16.150 [DEBUG] [.c.t.i.TransformationActivator:38 ] - Transformation Service has been started.
18:13:16.234 [DEBUG] [m.internal.MultimediaActivator:34 ] - Multimedia I/O bundle has been started.
18:13:16.262 [DEBUG] [.s.i.DiscoveryServiceActivator:27 ] - Discovery service has been started.
18:13:16.282 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:93 ] - mDNS service has been started
18:13:16.302 [DEBUG] [.io.transport.mqtt.MqttService:123 ] - Starting MQTT Service...
18:13:16.337 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:53 ] - Service Discovery initialization completed.
18:13:16.417 [DEBUG] [.i.internal.ItemModelActivator:24 ] - Registered 'item' configuration parser
18:13:16.531 [DEBUG] [o.o.c.i.items.ItemRegistryImpl:137 ] - Item provider 'GenericItemProvider' has been added.
18:13:17.323 [DEBUG] [.o.m.s.i.SitemapModelActivator:23 ] - Registered 'sitemap' configuration parser
18:13:17.395 [DEBUG] [io.rest.internal.RESTActivator:33 ] - REST API has been started.
18:13:18.456 [INFO ] [penhab.io.rest.RESTApplication:144 ] - Started REST API at /rest
18:13:18.457 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66 ] - Registering new service _openhab-server._tcp.local. at port 8080
18:13:23.944 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66 ] - Registering new service _openhab-server-ssl._tcp.local. at port 8443
18:13:25.985 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'default.sitemap'
18:13:26.137 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'test.items'
18:13:26.178 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'test.items'
18:13:26.184 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'test.items'
18:13:26.601 [INFO ] [.o.u.w.i.servlet.WebAppServlet:80 ] - Started Classic UI at /classicui/openhab.app
18:13:26.827 [DEBUG] [.r.internal.RuleModelActivator:42 ] - Registered 'rules' configuration parser
18:13:26.848 [DEBUG] [m.r.internal.engine.RuleEngine:77 ] - Started rule engine
18:13:29.633 [DEBUG] [.b.m.internal.MilightActivator:34 ] - Milight binding has been started.
18:13:29.672 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Light_Party2 (Type=SwitchItem, State=Uninitialized)' with 'MilightGenericBindingProvider' reader.
18:13:29.676 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Light_Party (Type=ColorItem, State=Uninitialized)' with 'MilightGenericBindingProvider' reader.
18:13:29.677 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'DiscoMode (Type=DimmerItem, State=Uninitialized)' with 'MilightGenericBindingProvider' reader.
18:13:29.677 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'DiscoSpeed (Type=DimmerItem, State=Uninitialized)' with 'MilightGenericBindingProvider' reader.
18:13:36.237 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'test.rules'
18:14:01.057 [DEBUG] [.o.b.m.internal.MilightBinding:96 ] - milight: item is of type brightness
18:14:01.058 [DEBUG] [.o.b.m.internal.MilightBinding:612 ] - milight: sendOn
18:14:01.058 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '22:00:55'
18:14:01.059 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '22:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:14:04.017 [DEBUG] [.o.b.m.internal.MilightBinding:96 ] - milight: item is of type brightness
18:14:04.017 [DEBUG] [.o.b.m.internal.MilightBinding:664 ] - milight: sendOff
18:14:04.018 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '21:00:55'
18:14:04.018 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '21:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:14:08.118 [DEBUG] [.o.b.m.internal.MilightBinding:96 ] - milight: item is of type brightness
18:14:08.118 [DEBUG] [.o.b.m.internal.MilightBinding:612 ] - milight: sendOn
18:14:08.118 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '22:00:55'
18:14:08.119 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '22:00:55' to bridge 'bridge1' (192.168.178.40:8899)
18:14:30.058 [DEBUG] [.o.b.m.internal.MilightBinding:170 ] - milight: item is of type rgb
18:14:30.059 [DEBUG] [.o.b.m.internal.MilightBinding:728 ] - milight: sendColor
18:14:30.059 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '20:b:55'
18:14:30.060 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '20:b:55' to bridge 'bridge1' (192.168.178.40:8899)
18:14:37.019 [DEBUG] [.o.b.m.internal.MilightBinding:170 ] - milight: item is of type rgb
18:14:37.019 [DEBUG] [.o.b.m.internal.MilightBinding:728 ] - milight: sendColor
18:14:37.020 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '20:d:55'
18:14:37.020 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet '20:d:55' to bridge 'bridge1' (192.168.178.40:8899)
18:14:49.341 [INFO ] [penhab.io.rest.RESTApplication:160 ] - Stopped REST API
18:14:49.341 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:80 ] - Unregistering service _openhab-server._tcp.local. at port 8080
18:14:51.345 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:80 ] - Unregistering service _openhab-server-ssl._tcp.local. at port 8443
I also did already a comparison of the milight related parts of both logs milight_compare.pdf (21.3 KB)
It is obvious that there a are fewer command sent to the bridge with the 1.8.3 binding.
I hope this is enough information to have a look at the binding code. I’m not really a java programmer to do this on my one.
Thanks for your support.
