I’ve defined several switches in OH 2 for the battery status for my Max! shutter contacts and assigned them to the group “Batteriestatus”:
Group Batteriestatus "Batteriestatus" <battery>
Switch Schlafzimmer_Fenster1_Battery "Batterie Schlafzimmerfenster 1 [MAP(max.map):%s]" <battery> (Batteriestatus) { channel="max:shuttercontact:NEQ0897054:LEQ0790848:battery_low" }
Switch Schlafzimmer_Fenster2_Battery "Batterie Schlafzimmerfenster 2 [MAP(max.map):%s]" <battery> (Batteriestatus) { channel="max:shuttercontact:NEQ0897054:LEQ0790893:battery_low" }
Because “OFF” means battery is ok and “ON” means battery has to be replaced, I also defined an appropriate “max.map” file:
OFF=ok
ON=leer
NULL=undefiniert
-=undefiniert
Now I want to display the status with my sitemap file:
sitemap zuHause label="Zu Hause"
Group item=Batteriestatus
Unfortunately when starting the BasicUI the elements below the Group “Batteriestatus” are still rendered as switches.
When I try
Text item=Schlafzimmer_Fenster1_Battery
Text item=Schlafzimmer_Fenster2_Battery
it is shown as expected:
“Batterie Schlafzimmerfenster 1 ok”
“Batterie Schlafzimmerfenster 2 ok”
What I understand is, that BasicUI renders the items below a group from the initial item type - so in this case “Switch” from my item file to “Switch” in the sitemap file.Right?
Are there any simple ways to enforce in the sitemap file to render the items below a group as “Text items”?
Many thanks in advance for a feedback.
