Help with rule for temp sensor
Please use the code fences when publishing code or logs
rule “Temperatur Sensoren Check”
    Item temp_wz changed or
    Item temp_bad_e changed or
    Item temp_vh_eg changed or
    Item temp_aussen changed or
    Item temp_pool changed
    Thread::sleep(100) // give persistence time to catch up
    if((triggeringItem.state as Number) == 100) {
        sendBroadcastNotification(triggeringItem.name.toString + " hat seit 5 Stunden kein Update erhalten")
3 errors there
val sensor = triggeringItem as Number
triggeringItem is an item and can’t be converted to a Number
It could have been: val sensor = triggeringItem as NumberItem but you don’t need it
When doing an equal test you need to use ==. A single = assigns a value.
triggeringItem.name to triggeringItem.name.toString
