Thanks for all your replies and suggestions.
Working on it and trying hard to understand it all.
My major problem is I don’t speak the code-language. So I don’t know where to put what.
For example can anyone guide me where I can find some documentation about all the ( ) { and}
Where and when do I need to put all these things?
rule "Licht schuur beweging"
Item Beweging_Schuur changed
if Item Beweging_Schuur.state == (ON)
sendCommand(Verlichting_Schuur, ON)
And an if there is a test. In your case you want to know if Beweging_Schuur is ON
The test must be between ()
After an if your instruction put these between {}
The first one say Here starts the if instruction
The last one } say, end of instructions
To send a command do this Verlichting_Schuur.sendCommand(ON)
So now you rule is:
if (Item Beweging_Schuur.state == ON) {
It can. Have you tried it? Rules DSL is pretty flexible about how you present stuff for your own reading clarity. Not at all flexible about having brackets and braces in pairs, though.
@Koensk if you are thinking about {} curly brackets, these are not essential, as long as only one command is executed.
rule testrule // quotes are optional, as long as the rule name is only one word
Item myItem changed // every time, the state of myItem changed
logInfo("test","test line 1")
if(myItem.state == OFF)
logInfo("test","test line 2")
logInfo("test","test line 3")
if(myItem.state == ON) {
logInfo("test","test line 4")
logInfo("test","test line 5")
When the rule is triggered,
the first log line is executed.
the second log line is only executed if the status of myItem is OFF.
the third log line will be executed, because the if statement will only apply to the first following line.
the fourth and fifth log line will only be executed if myItem is of state ON
So {} is used to build a block of commands.
Hope this didn’t add any confusion just thought it was something you might want to know.
For if and else statments here is a good reference. I keep it bookmarked.
