import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.java.math.*
import org.joda.time.*
var Timer CheckSinglePlayerTimer = null
var Timer SonosGroupVisibility = null
val Functions$Function6 updateSingleGroups = [
NumberItem group1_num,
NumberItem group2_num,
NumberItem group3_num,
StringItem player_a_groupID,
StringItem player_b_groupID,
StringItem player_a_name |
// If the player the updated player has been grouped to is in the "NONE"-group (or is NULL),
// find a group with zero players and update status of both players.
if(player_b_groupID.state=="0" || player_b_groupID.state==NULL) {
if(group1_num.state==0) {
postUpdate(player_a_groupID,"1")
postUpdate(player_b_groupID,"1")
logInfo("openhab", player_a_name + " player + 1 updated to group 1")
} else if(group2_num.state==0) {
postUpdate(player_a_groupID,"2")
postUpdate(player_b_groupID,"2")
logInfo("openhab", player_a_name + " player + 1 updated to group 2")
} else if(group3_num.state==0) {
postUpdate(player_a_groupID,"3")
postUpdate(player_b_groupID,"3")
logInfo("openhab", player_a_name + " player + 1 updated to group 3")
// Else set the updated player to the group id of the matched player
} else if(player_a_groupID.state!=player_b_groupID.state) {
postUpdate(player_a_groupID,player_b_groupID.state)
logInfo("openhab", player_a_name + " player updated to group " + player_b_groupID.state.toString)
return NULL
val Functions$Function6 checkSinglePlayers = [
StringItem CheckZonegroupID,
StringItem ZonegroupID_a,
StringItem ZonegroupID_b,
StringItem ZonegroupID_c,
StringItem UpdatePlayer,
StringItem UpdatePlayerName |
if(CheckZonegroupID.state!=ZonegroupID_a.state && CheckZonegroupID.state!=ZonegroupID_b.state && CheckZonegroupID.state!=ZonegroupID_c.state) {
postUpdate(UpdatePlayer,"0")
logInfo("openhab", UpdatePlayerName + "player updated to group 0")
return NULL
///// NUMBER OF PLAYERS IN GROUP
// A simple count of the number of players
// in each group is made. This is used in
// various rules, e.g. to determine
// if a group should be visible in the UI or not.
rule "Sonos number of players in group"
Item SonosGroupID_Kitc received update or
Item SonosGroupID_Gues received update or
Item SonosGroupID_Livi received update or
Item SonosGroupID_Bath received update
var Number Group_1 = 0
var Number Group_2 = 0
var Number Group_3 = 0
if(SonosGroupID_Kitc.state=="1"){
Group_1 = Group_1 + 1
}else if(SonosGroupID_Kitc.state=="2"){
Group_2 = Group_2 + 1
}else if(SonosGroupID_Kitc.state=="3"){
Group_3 = Group_3 + 1
if(SonosGroupID_Gues.state=="1"){
}else if(SonosGroupID_Gues.state=="2"){
}else if(SonosGroupID_Gues.state=="3"){
if(SonosGroupID_Bath.state=="1"){
}else if(SonosGroupID_Bath.state=="2"){
}else if(SonosGroupID_Bath.state=="3"){
if(SonosGroupID_Livi.state=="1"){
}else if(SonosGroupID_Livi.state=="2"){
}else if(SonosGroupID_Livi.state=="3"){
postUpdate(Sonos_Group1_Number,Group_1)
postUpdate(Sonos_Group2_Number,Group_2)
postUpdate(Sonos_Group3_Number,Group_3)
///// GROUPING RULES
// The rule will check every other player that the
// (1) Group number of the player beeing added corresponds to the player it is beeing added to
// (2) Zone-ids are not equal (not already grouped)
// (3) That the player beeing checked has a state (not NULL)
// Additional nested logic is required to determine in what direction the player shall be grouped (A to B or B to A).
// This is a special case that kicks in when both players are single before grouping: It is not possible
// to add a player that is the local coordinator to a player which is not.
rule "Sonos group kitchen"
Item SonosGroupID_Kitc received command
// Short sleep to make shure the rule to calculate the number of players in a group has executed before the logic is applied.
Thread::sleep(300)
if(SonosGroupID_Kitc.state==SonosGroupID_Gues.state && SonosGroupID_Kitc.state!="0" && Sonos_Kitc_ZoneGroupID.state!=Sonos_Gues_ZoneGroupID.state && Sonos_Gues_ZoneGroupID.state!=NULL && ((Sonos_Gues_LocalCoordinator.state==ON) || (Sonos_Kitc_LocalCoordinator.state==ON && ((SonosGroupID_Kitc.state=="1" && Sonos_Group1_Number.state=="2") || (SonosGroupID_Kitc.state=="2" && Sonos_Group2_Number.state=="2") || (SonosGroupID_Kitc.state=="3" && Sonos_Group3_Number.state=="2"))))){
logInfo("openhab","Entered sonos kitchen grouping rule number 1")
if(Sonos_Gues_LocalCoordinator.state==ON){
Sonos_Gues_Add.sendCommand("RINCON_B8E937B43B6C01400")
logInfo("openhab","Kitchen player added to guest room")
}else if(Sonos_Kitc_LocalCoordinator.state==ON && ((SonosGroupID_Kitc.state=="1" && Sonos_Group1_Number.state=="2") || (SonosGroupID_Kitc.state=="2" && Sonos_Group2_Number.state=="2") || (SonosGroupID_Kitc.state=="3" && Sonos_Group3_Number.state=="2"))) {
Sonos_Kitc_Add.sendCommand("RINCON_guestroomplayer")
logInfo("openhab","Guest room player added to kitchen")
}else if(SonosGroupID_Kitc.state==SonosGroupID_Bath.state && SonosGroupID_Kitc.state!="0" && Sonos_Kitc_ZoneGroupID.state!=Sonos_Bath_ZoneGroupID.state && Sonos_Bath_ZoneGroupID.state!=NULL && ((Sonos_Bath_LocalCoordinator.state==ON) || (Sonos_Kitc_LocalCoordinator.state==ON && ((SonosGroupID_Kitc.state=="1" && Sonos_Group1_Number.state=="2") || (SonosGroupID_Kitc.state=="2" && Sonos_Group2_Number.state=="2") || (SonosGroupID_Kitc.state=="3" && Sonos_Group3_Number.state=="2"))))){
logInfo("openhab","Entered sonos kitchen grouping rule number 2")
if(Sonos_Bath_LocalCoordinator.state==ON){
Sonos_Bath_Add.sendCommand("RINCON_B8E937B43B6C01400")
logInfo("openhab","Kitchen player added to bathroom")
Sonos_Kitc_Add.sendCommand("RINCON_bathroomplayer")
logInfo("openhab","Bathroom player added to kitchen")
}else if(SonosGroupID_Kitc.state==SonosGroupID_Livi.state && SonosGroupID_Kitc.state!="0" && Sonos_Kitc_ZoneGroupID.state!=Sonos_Livi_ZoneGroupID.state && Sonos_Livi_ZoneGroupID.state!=NULL && ((Sonos_Livi_LocalCoordinator.state==ON) || (Sonos_Kitc_LocalCoordinator.state==ON && ((SonosGroupID_Kitc.state=="1" && Sonos_Group1_Number.state=="2") || (SonosGroupID_Kitc.state=="2" && Sonos_Group2_Number.state=="2") || (SonosGroupID_Kitc.state=="3" && Sonos_Group3_Number.state=="2"))))){
logInfo("openhab","Entered sonos kitchen grouping rule number 3")
if(Sonos_Livi_LocalCoordinator.state==ON){
Sonos_Livi_Add.sendCommand("RINCON_B8E937B43B6C01400")
logInfo("openhab","Kitchen player added to living room")
Sonos_Kitc_Add.sendCommand("RINCON_000E58A5CBE201400")
logInfo("openhab","Living room player added to Kitchen")
}else{
Sonos_Kitc_StandAlone.sendCommand("ON")
logInfo("openhab","Kitchen player set to stand alone")
//// UPDATE GROUPING RULES
// The rules will update the appropiate group
// when a sonos player is grouped, either
// in the OH2 UI or within the Sonos app.
rule "Sonos update group membership bathroom"
Item Sonos_Bath_ZoneGroupID changed
if(Sonos_Bath_ZoneGroupID.state==Sonos_Kitc_ZoneGroupID.state && Sonos_Kitc_ZoneGroupID.state!=NULL) {
updateSingleGroups.apply(Sonos_Group1_Number, Sonos_Group2_Number, Sonos_Group3_Number, SonosGroupID_Bath, SonosGroupID_Kitc, "Bathroom")
} else if(Sonos_Bath_ZoneGroupID.state==Sonos_Gues_ZoneGroupID.state && Sonos_Gues_ZoneGroupID.state!=NULL) {
updateSingleGroups.apply(Sonos_Group1_Number, Sonos_Group2_Number, Sonos_Group3_Number, SonosGroupID_Bath, SonosGroupID_Gues, "Bathroom")
} else if(Sonos_Bath_ZoneGroupID.state==Sonos_Livi_ZoneGroupID.state && Sonos_Livi_ZoneGroupID.state!=NULL) {
updateSingleGroups.apply(Sonos_Group1_Number, Sonos_Group2_Number, Sonos_Group3_Number, SonosGroupID_Bath, SonosGroupID_Livi, "Bathroom")
// The zone-id changed, but is not grouped with any other players (removed from group).
// To allow grouping in the UI without the state being reset to single, a timer is applied.
// This works since grouping in both the OH UI and the Sonos app usually is not performed simultaneously.
} else {
if(CheckSinglePlayerTimer==null) {
CheckSinglePlayerTimer = createTimer(now.plusSeconds(20), [|
checkSinglePlayers.apply(Sonos_Bath_ZoneGroupID, Sonos_Kitc_ZoneGroupID, Sonos_Gues_ZoneGroupID, Sonos_Livi_ZoneGroupID, SonosGroupID_Bath,"Bathroom")
checkSinglePlayers.apply(Sonos_Kitc_ZoneGroupID, Sonos_Bath_ZoneGroupID, Sonos_Gues_ZoneGroupID, Sonos_Livi_ZoneGroupID, SonosGroupID_Kitc,"Kitchen")
checkSinglePlayers.apply(Sonos_Gues_ZoneGroupID, Sonos_Bath_ZoneGroupID, Sonos_Kitc_ZoneGroupID, Sonos_Livi_ZoneGroupID, SonosGroupID_Gues,"Guest room")
checkSinglePlayers.apply(Sonos_Livi_ZoneGroupID, Sonos_Bath_ZoneGroupID, Sonos_Kitc_ZoneGroupID, Sonos_Gues_ZoneGroupID, SonosGroupID_Livi,"Living room")
logInfo("openhab","CheckSinglePlayerTimer scheduled")
} else {
CheckSinglePlayerTimer.reschedule(now.plusSeconds(20))
logInfo("openhab","CheckSinglePlayerTimer rescheduled")
///// GROUP VISIBILITY
// The rule is used to control the UI.
// Specifically, it used to determin
// if a group should be hidden and if
// no, which player is to be shown within
// the group. This has to be the local
// coordinator in the group.
rule "Sonos group visibility"
Item SonosGroupID_Bath received update or
if(SonosGroupVisibility==null) {
SonosGroupVisibility = createTimer(now.plusSeconds(5), [|
if(Sonos_Group1_Number.state<=1){
postUpdate(Sonos_Group1_Visibility,"Hide")
}else if(Sonos_Group1_Number.state>=2){
if(SonosGroupID_Kitc.state=="1" && Sonos_Kitc_LocalCoordinator.state==ON){
postUpdate(Sonos_Group1_Visibility,"Kitchen")
}else if(SonosGroupID_Gues.state=="1" && Sonos_Gues_LocalCoordinator.state==ON){
postUpdate(Sonos_Group1_Visibility,"Guest room")
}else if(SonosGroupID_Bath.state=="1" && Sonos_Bath_LocalCoordinator.state==ON){
postUpdate(Sonos_Group1_Visibility,"Bathroom")
}else if(SonosGroupID_Livi.state=="1" && Sonos_Livi_LocalCoordinator.state==ON){
postUpdate(Sonos_Group1_Visibility,"Living room")
if(Sonos_Group2_Number.state<=1){
postUpdate(Sonos_Group2_Visibility,"Hide")
}else if(Sonos_Group2_Number.state>=2){
if(SonosGroupID_Kitc.state=="2" && Sonos_Kitc_LocalCoordinator.state==ON){
postUpdate(Sonos_Group2_Visibility,"Kitchen")
}else if(SonosGroupID_Gues.state=="2" && Sonos_Gues_LocalCoordinator.state==ON){
postUpdate(Sonos_Group2_Visibility,"Guest room")
}else if(SonosGroupID_Bath.state=="2" && Sonos_Bath_LocalCoordinator.state==ON){
postUpdate(Sonos_Group2_Visibility,"Bathroom")
}else if(SonosGroupID_Livi.state=="2" && Sonos_Livi_LocalCoordinator.state==ON){
postUpdate(Sonos_Group2_Visibility,"Living room")
if(Sonos_Group3_Number.state<=1){
postUpdate(Sonos_Group3_Visibility,"Hide")
}else if(Sonos_Group3_Number.state>=2){
if(SonosGroupID_Kitc.state=="3" && Sonos_Kitc_LocalCoordinator.state==ON){
postUpdate(Sonos_Group3_Visibility,"Kitchen")
}else if(SonosGroupID_Gues.state=="3" && Sonos_Gues_LocalCoordinator.state==ON){
postUpdate(Sonos_Group3_Visibility,"Guest room")
}else if(SonosGroupID_Bath.state=="3" && Sonos_Bath_LocalCoordinator.state==ON){
postUpdate(Sonos_Group3_Visibility,"Bathroom")
}else if(SonosGroupID_Livi.state=="3" && Sonos_Livi_LocalCoordinator.state==ON){
postUpdate(Sonos_Group3_Visibility,"Living room")
logInfo("openhab","SonosGroupVisibility scheduled")
} else {
SonosGroupVisibility.reschedule(now.plusSeconds(5))
logInfo("openhab","SonosGroupVisibility rescheduled")
response from openhab.log
2017-08-06 12:33:38.677 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'sonos1.rules', using it anyway:
The use of wildcard imports is deprecated.
Function6 is a raw type. References to generic type Function6<P1, P2, P3, P4, P5, P6, Result> should be parameterized
