Would you please share how to lock the car and how to start the heater.
Requesting all the information now works fine.
Thanks in advance.
Anyone who got heading or speed <> null from voc?
I never received a value except null
Switch VolvoHeater "Car Heater" <heating> (gVolvo, gPCR) [ "Switchable" ] { exec=">[ON:voc heater start] >[OFF:voc heater stop]" }
Switch VolvoEngine "Car Engine" <heating> (gVolvo, gPCR) [ "Switchable" ] { exec=">[ON:voc engine start] >[OFF:voc engine stop]" }
Switch VolvoLock "Car Lock" <lock> (gVolvo, gPCR) [ "Switchable" ] { exec=">[ON:voc lock]" }
Perfect!
Thanks a lot!
I will try it right away
Works like a charm.
Thanks again!
Please allow some more questions:
I can press and hold the lock button on my remote (key) to close the windows and roof.
Is there any option to do so through voc?
Furthermore is the function âhorn & flashâ as well as âflash headlightsâ somehow possible through voc?
You can not close windows and roof depending on that you can not do it from the app.
I you ask volvo to implement it in the app and then it will be possible.
You can do Honk and Blink with kind of âvoc call honkAndBlinkâ but i do not know the syntax.
Ah, thatâs what âcallâ is for!?
Thanks (again)
I actually got in touch with the Volvo support to find out if there are plans to implement âclose Windowsâ.
But I found another issue.
My data from the car is updated rarely and it seems itâs somehow depending on its movement.
When the car is locked and does not move, I have problems getting the right state of doors Windows and such.
As soon as I start the original Volvo app, it seems to trigger an update and I can retrieve the correct status from my Volvo right away.
It there something done differently by the Volvo app?
Anyone who can help me with changing the polling time?
The help says:
-I <interval> Polling interval (seconds) [default: 300]
So I tried:
/usr/local/bin/voc -u 'xxx' -p 'xxx' -I 120
and
/usr/local/bin/voc -u 'xxx' -p 'xxx' call -I 120
But just got the response of the help.
Any suggestion?
Hi, the polling interval is only used for the MQTT gateway.
Regarding data not being updated from the car: I have seen this myself as well. I do not know what the app is doing to force the server to ârefreshâ the car status. If anyone know or finds out, please let me know and I will try to add it.
Hi Erik,
thanks for your response.
I am glad that itâs not just me experiencing this issue.
So I guess it should be possible to use wireshark for investigation!?
One more question if you donât mind.
Retrieving the temperature at the vehicle is possible through the official VOC App, but I did not find this information using âprintâ oder âowntracksâ.
Is Temperature not avaiilable?
I havenât seen it available. My guess is that the app uses the location (gps coordinates) of the car and passes it to some external weather service to retrieve the current temperature at that location.
Good point - I can do that Thanks
By the way:
I just recognized that while driving itâs not possible to retrieve GPS data (even on the official VOC App itâs not possible).
I still donât know, why the official App obviously does something differently triggering / forcing a refresh
Thatâs how I did this now using weather underground.
If anyone needs details, just let me know
I actually found a possible workaround.
Just do a call request and VOC seems to refresh.
I just called âlockâ even though the car has been locked already.
After that the information was updatedi properly (I think
I started to work on a dedicated binding for VOC. Available in PR #3740. If somebody wants to git it a look - youâre welcome.
That sounds great.
I will test it as soon as I can spend some time.
is there a jar file for me to test?
Thanks in advance.
