I have a difficulty of cancelling a running timer. So the idea is when I turn ON a Switch, I also set up a timer that will turn it back OFF after 10 seconds. In case I turn the switch OFF manually within this 10 seconds interval, I want the previously create timer to be cancelled, but it seems that it doesn’t work this way for me. The timer is always null and if I switch ON/OFF 4 times, within a short period, 4 timers are created and executed.
rule "Siren switch"
Item siren01_manual_switch received command
var Timer timer = null
switch receivedCommand {
case ON: {
logInfo("test01","case ON")
case OFF: {
logInfo("test01","case OFF")
timer?.cancel()
logInfo("siren01","timer current state: " + timer)
if (timer === null) {
timer = createTimer(now.plusSeconds( 10 )) [|
logInfo("siren01","timer turning off " + timer)
postUpdate(siren01_manual_switch, OFF) ]
logInfo("siren01","Setting timer" + timer)
2021-02-15 15:49:00.902 [INFO ] [clipse.smarthome.model.script.test01] - case ON
2021-02-15 15:49:00.902 [INFO ] [lipse.smarthome.model.script.siren01] - timer current state: null
2021-02-15 15:49:00.903 [INFO ] [lipse.smarthome.model.script.siren01] - Setting timerorg.eclipse.smarthome.model.script.internal.actions.TimerImpl@2454d020
2021-02-15 15:49:01.284 [INFO ] [clipse.smarthome.model.script.test01] - case OFF
2021-02-15 15:49:01.285 [INFO ] [lipse.smarthome.model.script.siren01] - timer current state: null
2021-02-15 15:49:01.286 [INFO ] [lipse.smarthome.model.script.siren01] - Setting timerorg.eclipse.smarthome.model.script.internal.actions.TimerImpl@3d0f3c7f
2021-02-15 15:49:01.711 [INFO ] [clipse.smarthome.model.script.test01] - case ON
2021-02-15 15:49:01.711 [INFO ] [lipse.smarthome.model.script.siren01] - timer current state: null
2021-02-15 15:49:01.712 [INFO ] [lipse.smarthome.model.script.siren01] - Setting timerorg.eclipse.smarthome.model.script.internal.actions.TimerImpl@3be5ed7a
2021-02-15 15:49:02.156 [INFO ] [clipse.smarthome.model.script.test01] - case OFF
2021-02-15 15:49:02.156 [INFO ] [lipse.smarthome.model.script.siren01] - timer current state: null
2021-02-15 15:49:02.157 [INFO ] [lipse.smarthome.model.script.siren01] - Setting timerorg.eclipse.smarthome.model.script.internal.actions.TimerImpl@66b54392
2021-02-15 15:49:10.903 [INFO ] [lipse.smarthome.model.script.siren01] - timer turning off org.eclipse.smarthome.model.script.internal.actions.TimerImpl@2454d020
2021-02-15 15:49:11.285 [INFO ] [lipse.smarthome.model.script.siren01] - timer turning off org.eclipse.smarthome.model.script.internal.actions.TimerImpl@3d0f3c7f
2021-02-15 15:49:11.712 [INFO ] [lipse.smarthome.model.script.siren01] - timer turning off org.eclipse.smarthome.model.script.internal.actions.TimerImpl@3be5ed7a
2021-02-15 15:49:12.156 [INFO ] [lipse.smarthome.model.script.siren01] - timer turning off org.eclipse.smarthome.model.script.internal.actions.TimerImpl@66b54392
What am I doing wrong?
