Will test it out for you this weekend…
Thanks a lot!
As soon as a place in your new binding JAR file, I deleted the original 1.7 version, and re-activate my item where the URL has spaces in then I start getting this error in my logs. I did also make the change to the openhab.cfg file as suggested.
2016-07-02 11:51:30.980 [ERROR] [.service.AbstractActiveService] - Error while executing background thread HTTP Refresh Service
java.util.UnknownFormatConversionException: Conversion = ‘R’
at java.util.Formatter$FormatSpecifier.conversion(Unknown Source) ~[na:1.8.0_60]
at java.util.Formatter$FormatSpecifier.(Unknown Source) ~[na:1.8.0_60]
at java.util.Formatter.parse(Unknown Source) ~[na:1.8.0_60]
at java.util.Formatter.format(Unknown Source) ~[na:1.8.0_60]
at java.lang.String.format(Unknown Source) ~[na:1.8.0_60]
at org.openhab.binding.http.internal.HttpBinding.execute(HttpBinding.java:150) ~[na:na]
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:156) ~[na:na]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173) ~[na:na]
Once I disable the item then the error stops.
Looking at my HttpBinding.java, line 150, it looks like you may not have
http:format=false
in your openhab.cfg
file. Could you verify that your active openhab.cfg
file has that line? Tbanks.
John
This is what I have in my openhab.cfg file…
> ############################### HTTP Binding ##########################################
> # timeout in milliseconds for the http requests (optional, defaults to 5000)
> #http:timeout=
> http:format=false
> # the interval in milliseconds when to find new refresh candidates
> # (optional, defaults to 1000)
> #http:granularity=
> # configuration of the first cache item
> # http:<id1>.url=
> # http:<id1>.updateInterval=
> # configuration of the second cache item
> # http:<id2>.url=
> # http:<id2>.updateInterval=
Has anyone done this with the google directions api? I essentially want to get the duration of the route going two different ways to work (choosing the shortest of course). To do this I need to use the directions api to enter a waypoint to force the calculation of the other route. I have everything working except for the transform file. Can anyone help with the transform for the total duration?
"geocoded_waypoints" : [
"geocoder_status" : "OK",
"place_id" : "ChIJEZc1t0e1sGoR4KiOYlQ2AwU",
"types" : [ "locality", "political" ]
"place_id" : "EioyMzMgVGhlIFBhcmFkZSwgTm9yd29vZCBTQSA1MDY3LCBBdXN0cmFsaWE",
"types" : [ "street_address" ]
"place_id" : "ChIJP7Mmxcc1t2oRQMaOYlQ2AwQ",
"types" : [ "colloquial_area", "locality", "political" ]
"routes" : [
"bounds" : {
"northeast" : {
"lat" : -34.8697985,
"lng" : 138.7028416
"southwest" : {
"lat" : -34.9285019,
"lng" : 138.6006484
"copyrights" : "Map data ©2017 Google",
"legs" : [
"distance" : {
"text" : "10.3 km",
"value" : 10329
"duration" : {
"text" : "17 mins",
"value" : 994
"end_address" : "233 The Parade, Norwood SA 5067, Australia",
"end_location" : {
"lat" : -34.9210311,
"lng" : 138.6391782
"start_address" : "Athelstone SA 5076, Australia",
"start_location" : {
"lng" : 138.7028416
"steps" : [
"distance" : {
"text" : "1.4 km",
"value" : 1375
"duration" : {
"text" : "2 mins",
"value" : 107
"end_location" : {
"lat" : -34.8775505,
"lng" : 138.6914369
"html_instructions" : "Head \u003cb\u003esouth-west\u003c/b\u003e on \u003cb\u003eGorge Rd\u003c/b\u003e/\u003cb\u003eB31\u003c/b\u003e towards \u003cb\u003eFox Ave\u003c/b\u003e",
"polyline" : {
"points" : "foysEwkqmYZ|@Vl@@Bz@lBN\\FNVh@\\l@^f@zAjBt@z@dAnAf@l@bCzCdC~CvAhBRVn@z@rCpDh@r@j@t@d@n@d@l@hCfDJBT\\NVNVNX@@JTJXJXLb@HXF\\FVFl@Dd@B`@@L@TDZDZDZ"
"lng" : 138.7028416
"travel_mode" : "DRIVING"
"distance" : {
"text" : "1.0 km",
"value" : 989
"duration" : {
"text" : "1 min",
"value" : 85
"end_location" : {
"lat" : -34.8863886,
"lng" : 138.6920489
"html_instructions" : "At the roundabout, take the \u003cb\u003e1st\u003c/b\u003e exit onto \u003cb\u003eStradbroke Rd\u003c/b\u003e",
"maneuver" : "roundabout-left",
"polyline" : {
"points" : "t_{sEodomY@@@@@??@@@@??@PDNBD?H@RBvHUnAC|CMvBGpCKhCIzEOv@CbBGfBIvAE@?dBEHEBAn@S"
"lng" : 138.6914369
"distance" : {
"text" : "3.3 km",
"value" : 3313
"duration" : {
"text" : "6 mins",
"value" : 332
"end_location" : {
"lat" : -34.8895111,
"lng" : 138.6565514
"html_instructions" : "At the roundabout, take the \u003cb\u003e3rd\u003c/b\u003e exit onto \u003cb\u003eMontacute Rd\u003c/b\u003e",
"polyline" : {
"points" : "|v|sEihomY@A?A@?@A?A@?@A@?@?@AB?@?@?@?@?@@@?@@@?@@@@@@@@?@@@?@@@?@?@@@?@?@?D?@?@?@?@?@A@?@A@?@A@?@A@A@?h@?N?F?D@XB^DXFb@?BBNBDLj@\\~@FLf@fAx@vAP^JV@@L^V~@@DHb@Jv@Bj@FrB@vABvA@f@NfIDpBRfLDfCVnL@`@BpADjB@l@?JDzA?RD`ADtCBzA@l@Bx@BvA@v@@t@BjAB|A@j@BpAHlD?HBrABpAHnDHtD@z@@dAHlDBt@JlGHvDDdC?T@NJtG@l@@f@N`HB|@BtAFzC@v@?TJlF?|@DhB@t@"
"lng" : 138.6920489
"distance" : {
"text" : "1.7 km",
"value" : 1745
"duration" : {
"text" : "3 mins",
"value" : 171
"end_location" : {
"lat" : -34.8964383,
"lng" : 138.6393935
"html_instructions" : "Continue onto \u003cb\u003ePayneham Rd\u003c/b\u003e/\u003cb\u003eA11\u003c/b\u003e",
"polyline" : {
"points" : "lj}sEmjhmYBPFXDT@?HXl@nBh@jBHVj@pB\\jAZdAX|@x@pCPl@\\jATt@JZh@fBb@vAb@|Aj@jBd@|ARr@X`Af@bBpAjE~@`Dd@~A@DTv@f@xAl@vBn@xBv@lCX|@FRf@bBl@vBRp@^rAr@xBDPXr@Xj@Zn@"
"lng" : 138.6565514
"distance" : {
"text" : "92 m",
"value" : 92
"duration" : {
"text" : "1 min",
"value" : 11
"end_location" : {
"lat" : -34.8972464,
"lng" : 138.6392774
"html_instructions" : "Turn \u003cb\u003eleft\u003c/b\u003e onto \u003cb\u003eNational Highway A17\u003c/b\u003e",
"maneuver" : "turn-left",
"polyline" : {
"points" : "vu~sEe_emYH@TJLDL@d@F~@G"
"lng" : 138.6393935
"distance" : {
"text" : "2.6 km",
"value" : 2639
"duration" : {
"text" : "4 mins",
"value" : 239
"end_location" : {
"lat" : -34.92093759999999,
"lng" : 138.6410374
"html_instructions" : "Continue straight to stay on \u003cb\u003eNational Highway A17\u003c/b\u003e",
"maneuver" : "straight",
"polyline" : {
"points" : "xz~sEo~dmYjDKj@CvAEzCIhAI~@EH?rAC\\Ar@AD?dCKj@Az@CbAC`CIdBGbAENAlAEv@C^?bBGh@A`BEB?|AGrBGNApCIxAE~AGhAE^Al@A`DK|DOxBG|DMbBG|EQbEKp@CfDKr@C`BGl@CL?xCKpCIpAE~AGpAGl@E"
"lng" : 138.6392774
"distance" : {
"text" : "0.2 km",
"value" : 176
"duration" : {
"text" : "1 min",
"value" : 49
"end_location" : {
"lng" : 138.6391782
"html_instructions" : "Turn \u003cb\u003eright\u003c/b\u003e onto \u003cb\u003eThe Parade\u003c/b\u003e",
"maneuver" : "turn-right",
"polyline" : {
"points" : "znctEoiemYH?CT?`BBv@@x@DhC"
"lng" : 138.6410374
"traffic_speed_entry" : [],
"via_waypoint" : []
"distance" : {
"text" : "4.0 km",
"value" : 3989
"duration" : {
"text" : "11 mins",
"value" : 673
"end_address" : "Adelaide SA, Australia",
"end_location" : {
"lng" : 138.6007045
"start_address" : "233 The Parade, Norwood SA 5067, Australia",
"lng" : 138.6391782
"steps" : [
"distance" : {
"text" : "1.5 km",
"value" : 1474
"duration" : {
"text" : "4 mins",
"value" : 236
"end_location" : {
"lat" : -34.9218295,
"lng" : 138.6230431
"html_instructions" : "Head \u003cb\u003ewest\u003c/b\u003e on \u003cb\u003eThe Parade\u003c/b\u003e towards \u003cb\u003eQueen St\u003c/b\u003e",
"polyline" : {
"points" : "loctE{}dmY@n@@^JxEBh@HnDRjL@TFnEDjBDpB@d@BpBDrBHtEFlD@b@FpCBvAPjIBjBB`ABjADnBFzD?V"
"lng" : 138.6391782
"distance" : {
"text" : "0.5 km",
"value" : 499
"duration" : {
"text" : "1 min",
"value" : 72
"end_location" : {
"lat" : -34.9250593,
"lng" : 138.6192947
"html_instructions" : "Turn \u003cb\u003eleft\u003c/b\u003e onto \u003cb\u003eFlinders St\u003c/b\u003e",
"polyline" : {
"points" : "ltctE_yamYNXFJ@BRRrAvAxJfKj@n@TXRVJRFLBHDH?@DNFVFL"
"lng" : 138.6230431
"distance" : {
"text" : "0.6 km",
"value" : 588
"duration" : {
"text" : "1 min",
"value" : 68
"end_location" : {
"lat" : -34.9251206,
"lng" : 138.6128595
"html_instructions" : "Continue onto \u003cb\u003eBartels Rd\u003c/b\u003e",
"polyline" : {
"points" : "rhdtEqaamYJd@Dr@?H@\\?f@?`CAdB?pL?@?bAAvDA~@?BAh@?`@?r@"
"lng" : 138.6192947
"distance" : {
"text" : "88 m",
"value" : 88
"duration" : {
"text" : "1 min",
"value" : 22
"end_location" : {
"lat" : -34.9251701,
"lng" : 138.6118969
"html_instructions" : "Continue onto \u003cb\u003eEast Terrace\u003c/b\u003e",
"polyline" : {
"points" : "~hdtEky_mY?L@h@?HBf@?TB~@"
"lng" : 138.6128595
"distance" : {
"text" : "0.2 km",
"value" : 154
"duration" : {
"text" : "1 min",
"value" : 25
"end_location" : {
"lat" : -34.92655209999999,
"lng" : 138.6119493
"html_instructions" : "Turn \u003cb\u003eleft\u003c/b\u003e onto \u003cb\u003eHutt St\u003c/b\u003e",
"polyline" : {
"points" : "hidtEks_mYTA^?n@Ab@?|@?f@Ab@C"
"lng" : 138.6118969
"distance" : {
"text" : "1.0 km",
"value" : 1032
"duration" : {
"text" : "3 mins",
"value" : 208
"end_location" : {
"lat" : -34.9271185,
"lng" : 138.6006484
"html_instructions" : "Turn \u003cb\u003eright\u003c/b\u003e onto \u003cb\u003eFlinders St\u003c/b\u003e",
"polyline" : {
"points" : "|qdtEus_mY@TBdBF~B?\\Bt@L~GDxBDrBBvADfB@fABxAF~BDrBBfA@fADpABdBDvA@nAFbC@z@?ND~A"
"lng" : 138.6119493
"distance" : {
"text" : "0.2 km",
"value" : 154
"duration" : {
"text" : "1 min",
"value" : 42
"end_location" : {
"lng" : 138.6007045
"html_instructions" : "Turn \u003cb\u003eleft\u003c/b\u003e onto \u003cb\u003eVictoria Square\u003c/b\u003e",
"polyline" : {
"points" : "nudtEam}lYd@Al@C@?d@ARAXAP@RDXAh@C"
"lng" : 138.6006484
"via_waypoint" : []
"overview_polyline" : {
"points" : "foysEwkqmYr@jB|@pBVl@t@vAzBrCzBjChKrMbOtRJBT\\^n@h@jAX|@Pv@NdAHfANzAH^DBf@J\\DfKYpPk@~Me@xAEdBEHEr@U@A@ANGLBHFDNARGL?`AJxAN|@Lj@\\~@n@tAjAvBLXd@~AJh@NbBHjEZxPr@`_@JvF^bRhA~l@zAh|@F~CJj@~@~C|B`I`CbIbGdSdHdV|DxMvBlHlBpGr@~AZn@H@b@Pr@HjFSbCInHYjDGpHUzHYvNa@vx@gCvVw@hFUCT?`BDpBTrLb@zSp@|`@p@b]FrEVd@bNvN`AhA^j@Pb@`@zAFzAA`UC|HAbCDhBBtAt@AxDCb@C@TJdFVlNf@pW\\vRD~Ad@An@Cx@Cj@?RDXAh@C"
"summary" : "Montacute Rd and National Highway A17",
"warnings" : [],
"waypoint_order" : [ 0 ]
"status" : "OK"
