I have a mysensors node that I built that controls some leds I had laying around. I can manually send a hex value to the mqtt node and a value for brightness (below, sending white, 50% brightness)
ex: ffffff
mygateway1-in/2/1/1/0/40
and
50
mygateway1-in/2/1/1/0/3
Works no problem. I am trying to get the color picker in my sitemap to be able to control this. Not having any luck. I don’t see any change via the color picker, and nothing in the log.
Anyone have any kind of colorpicker setup to send hex?
I was able to figure it out. I ended up having to create a color item in openhab that takes in the color from the color picker. Then a rule to process the color to hex, which then updates a string item sent to the mqtt node that goes to mysensors.
