sossowski
(Stefan)
November 3, 2016, 1:29pm
1
I am the owner of the new Light sensor HM-Sen-LI-O.
I am using Raspi with Homegear version=0.6.7-1545 and Homematic version v1.8.3.
I’ve peered the new sensor sussessfully. But in Openhab logs I get the error:
2016-11-03 13:25:03.807 [WARN ] [.b.h.i.c.HomematicCommunicator] - Can't find DatapointConfig[address=NEQ123456,channel=0,parameter=RSSI_DEVICE], value is not published to openHAB!
2016-11-03 13:25:03.821 [WARN ] [.b.h.i.c.HomematicCommunicator] - Can't find DatapointConfig[address=NEQ123456,channel=1,parameter=LUX], value is not published to openHAB!
does anyone have an idea what I can do?
Dibbler42
(Thomas Bail)
November 3, 2016, 2:48pm
2
Restart openhab to reload all datapoints should solve the problem.
Thomas
sossowski
(Stefan)
November 3, 2016, 3:31pm
3
Thanks for your response!
Error message does not appear anymore. But I don’t get any values in my sitemap.
datapoint:
TYPE: float
channel type: LUXMETER
my item:
Number LichtsensorAussen "Lichtwert [f Lux]" <weather> (Aussen) { homematic="address=NEQ1234567, channel=1, parameter=LUX" }
my sitemap:
Text item=LichtsensorAussen label="Helligkeit Außen" icon="sun"
do you have any idea?
MRTUBT
(Mrtubt)
November 3, 2016, 4:15pm
4
Shouldn’t it be %f in:
Number LichtsensorAussen "Lichtwert [%f Lux]" <weather> (Aussen) {homematic="address=NEQ1234567, channel=1, parameter=LUX" }
Do you see updates coming in in homegear and in the openHAB events.log?
sossowski
(Stefan)
November 4, 2016, 10:27am
6
in homegear log file I can see something like this:
1/04/16 10:54:32.429 RPC client: Info: Calling RPC method "system.multicall" on server 127.0.0.1.
11/04/16 10:54:32.430 RPC client: Parameters:
(Array length=1)
(Struct length=2)
[methodName]
(String) event
[params]
(Array length=4)
(String) Homegear
(String) NEQ1356982:1
(String) LUX
(Float) 11960.1
so there is some data coming in.
but in openhab i don’t see anything in openhab.log there is nothing…
any ideas?
sossowski:
openhab.log
You have to look into events.log!
Everyone should know this section: http://docs.openhab.org/installation/linux.html#viewing-log-messages
sossowski
(Stefan)
November 4, 2016, 11:22am
8
Thank you for the hint!
in events.log is something:
2016-11-04 07:25:13 - LichtsensorAussen state updated to 42.46
2016-11-04 12:10:12 - LichtsensorAussen state updated to 11339.660004
How do I get this value to my sitemap?
Number LichtsensorAussen "Lichtwert [%f Lux]" <weather> (Aussen) { homematic="address=NEQ1356982, channel=1, parameter=LUX" }
In my sitemap I get no data
(on a side note: you need to either Reply on my post or reference me in this way @sossowski , otherwise I’ll not be informed directly of your answer.)
There is no “Number” Element in a sitemap, you might use which visual representation seems best fitting to you. Does make sense if you think about it.
Check: http://docs.openhab.org/features/sitemap.html#element-types
How about this?
Text item=LichtsensorAussen label="Lichtwert [%.1f lux]"
sossowski
(Stefan)
November 4, 2016, 7:10pm
10
hi @ThomDietrich
in my second post in this tread I had the sitemap this way
my sitemap:
Text item=LichtsensorAussen label=“Helligkeit Außen” icon=“sun”
all other posts had the item, not the sitemap.
but anyway, with your suggestion it is working. it seems that I was very out of it.
Please excuse this!
ah, I didn’t see that.
Your error was to define the label only as the label part without the value part. Without the […] you are telling openHAB to not display a value on the right part of the sitemap…
