I’ve got a HMIP-PSM wall plug, its switch channel is mapped to an item like this:
Switch PSM_HMIP_Relay_Switch "[MAP(dnd.map):%s]" (DefaultPersistenceNoRestore) {channel="homematic:HMIP-PSM:3014F711A061A7D709AC75E6:0001D3C99C3D0F:3#STATE" }
It’s included in my sitemap like this:
Switch item=PSM_HMIP_Relay_Switch label="Schaltsteckdose Diele[]"
Switching it on and off via the Basic UI works as expected.
Sending, from a python script:
events.sendCommand("PSM_HMIP_Relay_Switch", "ON")
does not work and consistently gives me this log error:
Device '0001D3C99C3D0F' is OFFLINE, can't send command 'ON' for channel 'homematic:HMIP-PSM:3014F711A061A7D709AC75E6:0001D3C99C3D0F:3#STATE'
I’ve checked the HomematicIP CCU Duty Cycle which stays below 14, all of the time. I’ve also tried to manually switch ON/OFF the wall plug a second before and after the respective rule does it. Manually switching always works (never get any OFFLINE error log message); sendCommand never does (always gives me the OFFLINE error log message). I’m puzzled as to what might be the problem?
