I have Openhab 3.2 up and running pretty stable.
The only leftover still is the epaper device WRCD.
I want to use it as a way to physically activate/deactivate cameras.
In order to have always the correct status globally, I created a script in ccu3 that displays the current camera status (on/off). This will be used to sync the status across virtual and physical buttons.
This variable is also mapped in OH3 as an item of the GATEWAY-EXTRAS thing.
What works:
- Button click on the device → proper update of status of variable in CCU3
- use the virtual switch of the item in OH3 → proper update of status of variable in CCU3
What does not work:
If the status of the variable changes, there is no update on the item. So the statusupdate of the ccu3 is not being recognized by the gateway-extras thing/item.
Errorlog is without entries.
Things (GATEWAY-EXTRAS, WRCD) have been deleteded and newly added.
Any help/indication would be highly appreciated
Rod
