I have a Secure SCS317 programmable thermostat (it is the same than a Hortsmann HRT4-ZW as it is recognised at this at openhab).
According to its documentation the thermostat setpoint command:
Supports HEAT and AWAY HEATING HEAT.
Set, is mapped to the temporary (advance) override. The sent set point will be applied to the end of the current heating cycle.
Get, reports the current target temperature.
AWAY HEATING
Sets and reports the temperature for both STANDBY and HOLIDAY modes.
I would like to access and configure this standby temperature from openhab. According to this I should create an item like:
Number scs317_standby_temp "Temperature: [%.1f C]" <temperature> (G_termostatos_temps) { zwave="6:command=thermostat_setpoint, refresh_interval=300" }
but I don’t know how to indicate that AWAY HEATING
option in the command. Is it possible? How?
