I have two thermostats setup and I can set the temp just fine but when I try and set the heat/cool mode I get a “No Response”. I have enabled TRACE logging and can see the output in the logs when I set the temp but there is no output when I try and set the heat/cool mode. Is this an accessories permissions issue?
Openhab Version:
openHAB 2.0.0~20170103034422 (Build #692)
My Config:
Switch ZWaveNode1545603FluorescentLightApplianceModule_Switch “Office Light” [ “Lighting” ]
Group gDownstairsThermostat “Downstairs Thermostat” [ “Thermostat” ]
Number zwave_device_e6b756d5_node10_sensor_temperature “Downstairs Thermostat Current Temperature” (gDownstairsThermostat) [ “CurrentTemperature” ]
Number DownstairsThermostat_SetpointHeating “Downstairs Thermostat Target Temperature” (gDownstairsThermostat) [ “TargetTemperature” ]
String DownstairsThermostat_ThermostatMode “Downstairs Thermostat Heating/Cooling Mode” (gDownstairsThermostat) [ “homekit:HeatingCoolingMode” ]
Group gUpstairsThermostat “Upstairs Thermostat” [ “Thermostat” ]
Number CurrentTemperature “Current Upstairs Temperature” (gUpstairsThermostat) [ “CurrentTemperature” ]
Number UpstairsThermostat_SetpointHeating “Upstairs Thermostat Target Temperature” (gUpstairsThermostat) [ “TargetTemperature” ]
String UpstairsThermostat_ThermostatMode “Upstairs Thermostat Mode” (gUpstairsThermostat) [ “homekit:HeatingCoolingMode” ]
Accessories output:
{“accessories”:[{“aid”:1,“services”:[{“iid”:1,“type”:“0000003E-0000-1000-8000-0026BB765291”,“characteristics”:[{“iid”:2,“type”:“00000023-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“Name of the accessory”,“value”:“openHAB”,“maxLen”:255},{“iid”:3,“type”:“00000020-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“The name of the manufacturer”,“value”:“openHAB”,“maxLen”:255},{“iid”:4,“type”:“00000021-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“The name of the model”,“value”:“2.0.0.201701021217”,“maxLen”:255},{“iid”:5,“type”:“00000030-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“The serial number of the accessory”,“value”:“none”,“maxLen”:255},{“iid”:6,“type”:“00000014-0000-1000-8000-0026BB765291”,“perms”:[“pw”],“format”:“bool”,“events”:false,“bonjour”:false,“description”:“Identifies the accessory via a physical action on the accessory”}]}]},{“aid”:1371401372,“services”:[{“iid”:1,“type”:“0000003E-0000-1000-8000-0026BB765291”,“characteristics”:[{“iid”:2,“type”:“00000023-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“Name of the accessory”,“value”:“Office Light”,“maxLen”:255},{“iid”:3,“type”:“00000020-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“The name of the manufacturer”,“value”:“none”,“maxLen”:255},{“iid”:4,“type”:“00000021-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“The name of the model”,“value”:“none”,“maxLen”:255},{“iid”:5,“type”:“00000030-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“The serial number of the accessory”,“value”:“none”,“maxLen”:255},{“iid”:6,“type”:“00000014-0000-1000-8000-0026BB765291”,“perms”:[“pw”],“format”:“bool”,“events”:false,“bonjour”:false,“description”:“Identifies the accessory via a physical action on the accessory”}]},{“iid”:7,“type”:“00000043-0000-1000-8000-0026BB765291”,“characteristics”:[{“iid”:8,“type”:“00000023-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“Name of the accessory”,“value”:“Office Light”,“maxLen”:255},{“iid”:9,“type”:“00000025-0000-1000-8000-0026BB765291”,“perms”:[“pw”,“pr”,“ev”],“format”:“bool”,“events”:false,“bonjour”:false,“description”:“Turn on and off”,“value”:false}]}]},{“aid”:1098259991,“services”:[{“iid”:1,“type”:“0000003E-0000-1000-8000-0026BB765291”,“characteristics”:[{“iid”:2,“type”:“00000023-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“Name of the accessory”,“value”:“Upstairs Thermostat”,“maxLen”:255},{“iid”:3,“type”:“00000020-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“The name of the manufacturer”,“value”:“none”,“maxLen”:255},{“iid”:4,“type”:“00000021-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“The name of the model”,“value”:“none”,“maxLen”:255},{“iid”:5,“type”:“00000030-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“The serial number of the accessory”,“value”:“none”,“maxLen”:255},{“iid”:6,“type”:“00000014-0000-1000-8000-0026BB765291”,“perms”:[“pw”],“format”:“bool”,“events”:false,“bonjour”:false,“description”:“Identifies the accessory via a physical action on the accessory”}]},{“iid”:7,“type”:“0000004A-0000-1000-8000-0026BB765291”,“characteristics”:[{“iid”:8,“type”:“00000023-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“Name of the accessory”,“value”:“Upstairs Thermostat”,“maxLen”:255},{“iid”:9,“type”:“0000000F-0000-1000-8000-0026BB765291”,“perms”:[“pr”,“ev”],“format”:“int”,“events”:false,“bonjour”:false,“description”:“Current Mode”,“value”:0,“minValue”:0,“maxValue”:3,“minStep”:1},{“iid”:10,“type”:“00000011-0000-1000-8000-0026BB765291”,“perms”:[“pr”,“ev”],“format”:“float”,“events”:false,“bonjour”:false,“description”:“Current Temperature”,“value”:21.0,“minValue”:-100.0,“maxValue”:100.0,“minStep”:0.1,“unit”:“celsius”},{“iid”:11,“type”:“00000033-0000-1000-8000-0026BB765291”,“perms”:[“pr”,“ev”],“format”:“int”,“events”:false,“bonjour”:false,“description”:“Target Mode”,“value”:0,“minValue”:0,“maxValue”:3,“minStep”:1},{“iid”:12,“type”:“00000035-0000-1000-8000-0026BB765291”,“perms”:[“pw”,“pr”,“ev”],“format”:“float”,“events”:false,“bonjour”:false,“description”:“Target Temperature”,“value”:25.0,“minValue”:-100.0,“maxValue”:100.0,“minStep”:0.1,“unit”:“celsius”},{“iid”:13,“type”:“00000036-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“int”,“events”:false,“bonjour”:false,“description”:“The temperature unit”,“value”:1,“minValue”:0,“maxValue”:1,“minStep”:1}]}]},{“aid”:1096626271,“services”:[{“iid”:1,“type”:“0000003E-0000-1000-8000-0026BB765291”,“characteristics”:[{“iid”:2,“type”:“00000023-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“Name of the accessory”,“value”:“Downstairs Thermostat”,“maxLen”:255},{“iid”:3,“type”:“00000020-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“The name of the manufacturer”,“value”:“none”,“maxLen”:255},{“iid”:4,“type”:“00000021-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“The name of the model”,“value”:“none”,“maxLen”:255},{“iid”:5,“type”:“00000030-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“The serial number of the accessory”,“value”:“none”,“maxLen”:255},{“iid”:6,“type”:“00000014-0000-1000-8000-0026BB765291”,“perms”:[“pw”],“format”:“bool”,“events”:false,“bonjour”:false,“description”:“Identifies the accessory via a physical action on the accessory”}]},{“iid”:7,“type”:“0000004A-0000-1000-8000-0026BB765291”,“characteristics”:[{“iid”:8,“type”:“00000023-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“string”,“events”:false,“bonjour”:false,“description”:“Name of the accessory”,“value”:“Downstairs Thermostat”,“maxLen”:255},{“iid”:9,“type”:“0000000F-0000-1000-8000-0026BB765291”,“perms”:[“pr”,“ev”],“format”:“int”,“events”:false,“bonjour”:false,“description”:“Current Mode”,“value”:0,“minValue”:0,“maxValue”:3,“minStep”:1},{“iid”:10,“type”:“00000011-0000-1000-8000-0026BB765291”,“perms”:[“pr”,“ev”],“format”:“float”,“events”:false,“bonjour”:false,“description”:“Current Temperature”,“value”:19.4,“minValue”:-100.0,“maxValue”:100.0,“minStep”:0.1,“unit”:“celsius”},{“iid”:11,“type”:“00000033-0000-1000-8000-0026BB765291”,“perms”:[“pr”,“ev”],“format”:“int”,“events”:false,“bonjour”:false,“description”:“Target Mode”,“value”:0,“minValue”:0,“maxValue”:3,“minStep”:1},{“iid”:12,“type”:“00000035-0000-1000-8000-0026BB765291”,“perms”:[“pw”,“pr”,“ev”],“format”:“float”,“events”:false,“bonjour”:false,“description”:“Target Temperature”,“value”:23.9,“minValue”:-100.0,“maxValue”:100.0,“minStep”:0.1,“unit”:“celsius”},{“iid”:13,“type”:“00000036-0000-1000-8000-0026BB765291”,“perms”:[“pr”],“format”:“int”,“events”:false,“bonjour”:false,“description”:“The temperature unit”,“value”:1,“minValue”:0,“maxValue”:1,“minStep”:1}]}]}]}
