@kjknauss Before rebooting, did you try disabling / enabling the bridge? This shouldn’t happen though.
I have also uploaded v0.0.14 to match the current state of the PR.
I did try disable/enable. The only thing that refreshed items was saving the bridge thing, but that wasn’t persistent. Maybe something local to my machine was the cause.
Something else: I am using the label filter (great option btw), and I tried bringing in the openweathermap integration but it never showed up in the Inbox.
We’d need to get to the bottom of this somehow.
Can you please:
@kjknauss please try v0.0.15 - it should include openweathermap in the discovery inbox if you add a tag / label to it.
That worked.
Here are the channels for Open Weather Map. HA shows 18 entities, but many more here.
version: 1
things:
hasslink:device:04510bcffc3543cbb0b14bf781b1a67d:3a65ad38a363fc0e59381a1267f40ce6:
bridge: hasslink:server:04510bcffc3543cbb0b14bf781b1a67d
label: Open Weather Map Hasslink
deviceId: 3a65ad38a363fc0e59381a1267f40ce6
channels:
weather-openweathermap:
type: string
label: Weather (Weather)
entityId: weather.openweathermap
autoCreated: true
sensor-weather:
type: string
label: Weather (Sensor)
entityId: sensor.openweathermap_weather
autoCreated: true
weather-openweathermap#cloud_coverage:
type: number
label: Weather Cloud Coverage
attribute: cloud_coverage
autoCreated: true
weather-openweathermap#humidity:
type: number
label: Weather Humidity
attribute: humidity
autoCreated: true
weather-openweathermap#apparent_temperature:
type: number
label: Weather Apparent Temperature
attribute: apparent_temperature
autoCreated: true
weather-openweathermap#dew_point:
type: number
label: Weather Dew Point
attribute: dew_point
autoCreated: true
weather-openweathermap#pressure:
type: number
label: Weather Pressure
attribute: pressure
autoCreated: true
weather-openweathermap#temperature:
type: number
label: Weather Temperature
attribute: temperature
autoCreated: true
weather-openweathermap#visibility:
type: number
label: Weather Visibility
attribute: visibility
autoCreated: true
weather-openweathermap#wind_gust_speed:
type: number
label: Weather Wind Gust Speed
attribute: wind_gust_speed
autoCreated: true
weather-openweathermap#wind_speed:
type: number
label: Weather Wind Speed
attribute: wind_speed
autoCreated: true
weather-openweathermap#wind_bearing:
type: number
label: Weather Wind Bearing
attribute: wind_bearing
autoCreated: true
weather-openweathermap#forecast_pressure:
type: number
label: Weather Forecast Pressure
attribute: forecast_pressure
autoCreated: true
weather-openweathermap#forecast_uv_index:
type: number
label: Weather Forecast Uv Index
attribute: forecast_uv_index
autoCreated: true
weather-openweathermap#forecast_dew_point:
type: number
label: Weather Forecast Dew Point
attribute: forecast_dew_point
autoCreated: true
weather-openweathermap#forecast_wind_bearing:
type: number
label: Weather Forecast Wind Bearing
attribute: forecast_wind_bearing
autoCreated: true
weather-openweathermap#forecast_precipitation_probability:
type: number
label: Weather Forecast Precipitation Probability
attribute: forecast_precipitation_probability
autoCreated: true
weather-openweathermap#forecast_wind_speed:
type: number
label: Weather Forecast Wind Speed
attribute: forecast_wind_speed
autoCreated: true
weather-openweathermap#forecast_wind_gust_speed:
type: number
label: Weather Forecast Wind Gust Speed
attribute: forecast_wind_gust_speed
autoCreated: true
weather-openweathermap#forecast_templow:
type: number
label: Weather Forecast Templow
attribute: forecast_templow
autoCreated: true
weather-openweathermap#forecast_humidity:
type: number
label: Weather Forecast Humidity
attribute: forecast_humidity
autoCreated: true
weather-openweathermap#forecast_condition:
type: string
label: Weather Forecast Condition
attribute: forecast_condition
autoCreated: true
weather-openweathermap#forecast_precipitation:
type: number
autoCreated: true
weather-openweathermap#forecast_apparent_temperature:
type: number
label: Weather Forecast Apparent Temperature
attribute: forecast_apparent_temperature
autoCreated: true
weather-openweathermap#forecast_temperature:
type: number
label: Weather Forecast Temperature
attribute: forecast_temperature
autoCreated: true
weather-openweathermap#forecast_cloud_coverage:
type: number
label: Weather Forecast Cloud Coverage
attribute: forecast_cloud_coverage
autoCreated: true
weather-openweathermap#forecast_hourly_pressure:
type: number
label: Weather Forecast Hourly Pressure
attribute: forecast_hourly_pressure
autoCreated: true
weather-openweathermap#forecast_hourly_uv_index:
type: number
label: Weather Forecast Hourly Uv Index
attribute: forecast_hourly_uv_index
autoCreated: true
weather-openweathermap#forecast_hourly_dew_point:
type: number
label: Weather Forecast Hourly Dew Point
attribute: forecast_hourly_dew_point
autoCreated: true
weather-openweathermap#forecast_hourly_wind_bearing:
type: number
label: Weather Forecast Hourly Wind Bearing
attribute: forecast_hourly_wind_bearing
autoCreated: true
weather-openweathermap#forecast_hourly_precipitation_probability:
type: number
label: Weather Forecast Hourly Precipitation Probability
attribute: forecast_hourly_precipitation_probability
autoCreated: true
weather-openweathermap#forecast_hourly_wind_speed:
type: number
label: Weather Forecast Hourly Wind Speed
attribute: forecast_hourly_wind_speed
autoCreated: true
weather-openweathermap#forecast_hourly_wind_gust_speed:
type: number
label: Weather Forecast Hourly Wind Gust Speed
attribute: forecast_hourly_wind_gust_speed
autoCreated: true
weather-openweathermap#forecast_hourly_templow:
type: number
label: Weather Forecast Hourly Templow
attribute: forecast_hourly_templow
autoCreated: true
weather-openweathermap#forecast_hourly_humidity:
type: number
label: Weather Forecast Hourly Humidity
attribute: forecast_hourly_humidity
autoCreated: true
weather-openweathermap#forecast_hourly_condition:
type: string
label: Weather Forecast Hourly Condition
attribute: forecast_hourly_condition
autoCreated: true
weather-openweathermap#forecast_hourly_precipitation:
type: number
autoCreated: true
weather-openweathermap#forecast_hourly_apparent_temperature:
type: number
label: Weather Forecast Hourly Apparent Temperature
attribute: forecast_hourly_apparent_temperature
autoCreated: true
weather-openweathermap#forecast_hourly_temperature:
type: number
label: Weather Forecast Hourly Temperature
attribute: forecast_hourly_temperature
autoCreated: true
weather-openweathermap#forecast_hourly_cloud_coverage:
type: number
label: Weather Forecast Hourly Cloud Coverage
attribute: forecast_hourly_cloud_coverage
autoCreated: true
sensor-apparent_temperature:
type: number
label: Apparent Temperature
entityId: sensor.openweathermap_apparent_temperature
autoCreated: true
sensor-apparent_temperature#attribution:
type: string
label: Apparent Temperature Attribution
attribute: attribution
autoCreated: true
sensor-cloud_coverage:
type: number
label: Cloud Coverage
entityId: sensor.openweathermap_cloud_coverage
autoCreated: true
sensor-cloud_coverage#attribution:
type: string
label: Cloud Coverage Attribution
autoCreated: true
sensor-condition:
type: string
label: Condition
entityId: sensor.openweathermap_condition
autoCreated: true
sensor-condition#attribution:
type: string
label: Condition Attribution
autoCreated: true
sensor-dew_point_temperature:
type: number
label: Dew Point Temperature
entityId: sensor.openweathermap_dew_point_temperature
autoCreated: true
sensor-dew_point_temperature#attribution:
type: string
label: Dew Point Temperature Attribution
autoCreated: true
sensor-humidity:
type: number
label: Humidity
entityId: sensor.openweathermap_humidity
autoCreated: true
sensor-humidity#attribution:
type: string
label: Humidity Attribution
autoCreated: true
sensor-precipitation_kind:
type: string
label: Precipitation Kind
entityId: sensor.openweathermap_precipitation_kind
autoCreated: true
sensor-precipitation_kind#attribution:
type: string
label: Precipitation Kind Attribution
autoCreated: true
sensor-pressure:
type: number
label: Pressure
entityId: sensor.openweathermap_pressure
autoCreated: true
sensor-pressure#attribution:
type: string
label: Pressure Attribution
autoCreated: true
sensor-rain_intensity:
type: number
label: Rain Intensity
entityId: sensor.openweathermap_rain_intensity
autoCreated: true
sensor-rain_intensity#attribution:
type: string
label: Rain Intensity Attribution
autoCreated: true
sensor-snow_intensity:
type: number
label: Snow Intensity
entityId: sensor.openweathermap_snow_intensity
autoCreated: true
sensor-snow_intensity#attribution:
type: string
label: Snow Intensity Attribution
autoCreated: true
sensor-temperature:
type: number
label: Temperature
entityId: sensor.openweathermap_temperature
autoCreated: true
sensor-temperature#attribution:
type: string
label: Temperature Attribution
autoCreated: true
sensor-uv_index:
type: number
label: UV Index
entityId: sensor.openweathermap_uv_index
autoCreated: true
sensor-uv_index#attribution:
type: string
label: UV Index Attribution
autoCreated: true
sensor-visibility:
type: number
label: Visibility
entityId: sensor.openweathermap_visibility
autoCreated: true
sensor-visibility#attribution:
type: string
label: Visibility Attribution
autoCreated: true
sensor-weather#attribution:
type: string
label: Weather Attribution
autoCreated: true
sensor-weather_code:
type: number
label: Weather Code
entityId: sensor.openweathermap_weather_code
autoCreated: true
sensor-weather_code#attribution:
type: string
label: Weather Code Attribution
autoCreated: true
sensor-wind_direction:
type: number
label: Wind Direction
entityId: sensor.openweathermap_wind_direction
autoCreated: true
sensor-wind_direction#attribution:
type: string
label: Wind Direction Attribution
autoCreated: true
sensor-wind_gust_speed:
type: number
label: Wind Gust Speed
entityId: sensor.openweathermap_wind_gust_speed
autoCreated: true
sensor-wind_gust_speed#attribution:
type: string
label: Wind Gust Speed Attribution
autoCreated: true
sensor-wind_speed:
type: number
label: Wind Speed
entityId: sensor.openweathermap_wind_speed
autoCreated: true
sensor-wind_speed#attribution:
type: string
label: Wind Speed Attribution
autoCreated: true
Why would one use a HA integration if we have an native binding for openweathermap?
Wouldn’t it be better to add any missing feature to the openHAB binding?
I use the native binding. Just testing.
Ahhh. That makes sense, now ![]()
Indeed.
1 Entity in HA can carry composite data within its attributes. Especially so in a weather entity, and especially so for openweathermap because it has forecast data too. Each attribute is represented as a separate channel in openHAB.
I am actually curious to see if the TimeSeries adaptation works here, as I have only written the code but never tested it.
