Thanks a lot for the fix, the new version works so far.
By the way: Do you have a roadmap for integrating an official binding in OH2 ? Apart from the refresh hickups in the past few weeks, the binding seems to be very stable. I would say the beta test is a success
Hey guys,
thanks for this wonderful binding! I reinstalled the newest version (incl. creating a new app on dev side and token etc) and are getting this error after creating coffemachine thing from via autodiscovery (Thing :
'homeconnect:CoffeeMaker:SIEMENS-TI9575X1DE-68A40E251D47' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): Communication error! response code: 403, message: Forbidden, body: {
"error": {
"key": "insufficient_scope",
"description": "Not allowed to access this HomeAppliance"
One of my main usecases is to turn the machine on and off.
Since you do not support this in your addon right now, i forked your project and build a quick and dirty workaround on my own, which worked for me.
Should i make a Pull-Request on your Git-Project, when it is not only a quick-solution?
My first thought was that you used a different account during oAuth authorization. But you said, youâve added it via autodiscovery which should only show your devices.
âinsufficient_scopeâ
Did you unselected anything on the following page?
Thx 4 answering jb4711, everything was checked on that page correctly
//Edit:
You wont believe me if I tell you that I remembered replacing our coffee machine due to a warranty issue. OH2 automatically added the old haid and not he new one. There was also only 1 character different within the serial no so I didnât recognize⊠OooohhhhaaaaâŠ
I have again a problem with the connection. I get the folowing error:
'homeconnect:api_bridge:cb18b336' changed from INITIALIZING to OFFLINE (COMMUNICATION_ERROR): Communication error! response code: 400, message: Bad Request, body: {
"error": "invalid_grant",
"error_description": "invalid refresh_token"
} (Tried at Sun Jan 13 18:20:06 CET 2019)
Binding Version from 2018/12/30
Any Ideas? Thank you for your help!
after installation of binding, items file, thing file and access data of Home Connect from developer page and normal page, there two big failures left, which I cannot drill down. In the moment I cannot see the wood for the trees! Both Home appliances are running fine on the Home Connect iOS app.
from where can I get the complete haID for my haâs for the thing-file? I am searching for the âXXXXXXXXXXBFâ terms of both haâs in thing-file.
If I remember correctly, I was only able to find that in the PaperUI. Even if you configure it with files, you should be able to find the haID in the inbox.
The second error to me really looks like a temporary connection problem on the server side.
