Hello Jonas, Iâm using your addon with great joy on my Siemens WM14T6H6NL washing machine.
Version: 2.5.9
Until now, everything Iâve tried with it works.
Iâve ran in a problem today, though. I tried to set a delayed start program on it, but I get the error:
Option BSH.Common.Option.FinishInRelative not supported
Am I doing something wrong here or is this a known limitation of the addon/developer program?
Could not handle command { "data": { "key": "LaundryCare.Washer.Program.Sensitive", "options": [ { "key": "BSH.Common.Option.FinishInRelative", "value": 1200, "unit": "seconds" }, { "key": "LaundryCare.Common.Option.LoadRecommendation", "value": 6500, "unit": "gram" }, { "key": "LaundryCare.Common.Option.VarioPerfect", "value": "LaundryCare.Common.EnumType.VarioPerfect.Off" }, { "key": "LaundryCare.Washer.Option.IDos1DosingLevel", "value": "LaundryCare.Washer.EnumType.IDosingLevel.Off" }, { "key": "LaundryCare.Washer.Option.IDos2DosingLevel", "value": "LaundryCare.Washer.EnumType.IDosingLevel.Off" }, { "key": "LaundryCare.Washer.Option.LessIroning", "value": true }, { "key": "LaundryCare.Washer.Option.Prewash", "value": false }, { "key": "LaundryCare.Washer.Option.SpinSpeed", "value": "LaundryCare.Washer.EnumType.SpinSpeed.RPM800" }, { "key": "LaundryCare.Washer.Option.Temperature", "value": "LaundryCare.Washer.EnumType.Temperature.GC60" }, { "key": "LaundryCare.Washer.Option.WaterAndRinsePlus", "value": "LaundryCare.Washer.EnumType.WaterAndRinsePlus.Off" } ] } }. API communication problem! error: Communication error! response code: 409, message: Conflict, body: { "error": { "key": "SDK.Error.UnsupportedOption", "description": "Option BSH.Common.Option.FinishInRelative not supported" } } (Tried at Sat Oct 24 00:56:54 CEST 2020)
If I remove the FinishInRelative part, and reissue the curl command, the command fails another time, but now on an other part:
Could not handle command { "data": { "key": "LaundryCare.Washer.Program.Sensitive", "options": [ { "key": "LaundryCare.Common.Option.LoadRecommendation", "value": 6500, "unit": "gram" }, { "key": "LaundryCare.Common.Option.VarioPerfect", "value": "LaundryCare.Common.EnumType.VarioPerfect.Off" }, { "key": "LaundryCare.Washer.Option.IDos1DosingLevel", "value": "LaundryCare.Washer.EnumType.IDosingLevel.Off" }, { "key": "LaundryCare.Washer.Option.IDos2DosingLevel", "value": "LaundryCare.Washer.EnumType.IDosingLevel.Off" }, { "key": "LaundryCare.Washer.Option.LessIroning", "value": true }, { "key": "LaundryCare.Washer.Option.Prewash", "value": false }, { "key": "LaundryCare.Washer.Option.SpinSpeed", "value": "LaundryCare.Washer.EnumType.SpinSpeed.RPM800" }, { "key": "LaundryCare.Washer.Option.Temperature", "value": "LaundryCare.Washer.EnumType.Temperature.GC60" }, { "key": "LaundryCare.Washer.Option.WaterAndRinsePlus", "value": "LaundryCare.Washer.EnumType.WaterAndRinsePlus.Off" } ] } }. API communication problem! error: Communication error! response code: 409, message: Conflict, body: { "error": { "key": "SDK.Error.UnsupportedOption", "description": "Option LaundryCare.Common.Option.LoadRecommendation not supported" } } (Tried at Sat Oct 24 01:20:39 CEST 2020)
All help is welcome.
