hello there,
so far it works but I have the issue: how can I get the haId from my devices?
Thing oven oven1 "Oven" [ haId="BOSCH-????????-????????????" ]
Thanks in advanced
hello there,
Thanks in advanced
http://[ipAddress]:8080/homeconnect/appliances (where [ipAddress] is the dotted IP Address of your openHAB computer)
but I needed the hdid before.
When I go to this URL there is nothing
I have a question, will more channels be added for the oven?
e.g.: Fast Pre-heat Option
And does anyone have a ready-made sitemap for the oven they are providing?
Just updated from OH 3.0.1 to 3.0.2 and the beta jar does not work anymore:
2021-04-24 17:55:42.534 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/home/mythtv/openHAB/addons/org.openhab.binding.homeconnect-3.1.0.202101161431.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.homeconnect [208]
Unresolved requirement: Import-Package: android.net.http; resolution:="optional"
Unresolved requirement: Import-Package: android.net.ssl; resolution:="optional"
Unresolved requirement: Import-Package: android.os; resolution:="optional"
Unresolved requirement: Import-Package: android.security; resolution:="optional"
Unresolved requirement: Import-Package: android.util; resolution:="optional"
Unresolved requirement: Import-Package: com.android.org.conscrypt; resolution:="optional"
Unresolved requirement: Import-Package: dalvik.system; resolution:="optional"
Unresolved requirement: Import-Package: org.conscrypt; resolution:="optional"
Unresolved requirement: Import-Package: sun.security.ssl; resolution:="optional"
Unresolved requirement: Import-Package: javax.annotation.meta; resolution:="optional"
Unresolved requirement: Import-Package: com.sun.jdi; resolution:="optional"
Unresolved requirement: Import-Package: com.sun.jdi.connect; resolution:="optional"
Unresolved requirement: Import-Package: com.sun.jdi.event; resolution:="optional"
Unresolved requirement: Import-Package: com.sun.jdi.request; resolution:="optional"
Unresolved requirement: Import-Package: org.apache.commons.lang; version="[2.6.0,3.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
Is there an updated version available?
Edit:
Nevermind, after restart of openHAB, it works.
Iâm getting again error 429 (too many requests) for my dryer and washing machine.
Same happened last week - then I disabled the Things for 1 day and enabled it again this morning.
However, after some hours, the same problem occurs again.
I encountered the same error. Can you please check if a resent timestamp in shown in the web ui under âLast Event received (SSE)â (appliance). Somehow the binding wonât establish a SSE connection and is trying to establish it again. This wonât work â 429 Error
I will try to have a look at the code etc. tomorrow.
Hi Jonas,
I sent you my logs in a PM. Not sure this helps.
Let me know if you want me to check anything else.
thanks
Stefan
As part of the inclusion as a ârealâ add-on in OpenHAB, Iâm currently working on ambient and functional light support for hoods and dishwashers.
Since I donât have a device with a light function, I need your help. Would it be possible for you to test the light function? Only the brightness switch has changed since the last version. A dimmer item is now used.
Version for openHAB 3.0.x: org.openhab.binding.homeconnect-3.1.0.202105021551-build-for-3.0.2.jar
Version for openHAB 3.1.0-SNAPSHOT: org.openhab.binding.homeconnect-3.1.0.202105021551-build-for-3.1.0-SNAPSHOT.jar
Thank very much for your help,
JB
I will have a look once the binding is accepted as official addon.
Hi Jonas,
I donât have a Openhab 3.0 running yet. Iâll do my best to set one up in the coming weeks!
grtz
Steven
2021/05/06
3.0.x / 3.1.0
Download 3.0.x: org.openhab.binding.homeconnect-3.1.0.202105061011-3.0.2.jar
Download 3.1.0-SNAPSHOT: org.openhab.binding.homeconnect-3.1.0.202105061017-3.1.0-SNAPSHOT.jar
Change log:
Dimmer
2.5.x
Download 2.5.x: org.openhab.binding.homeconnect-2.5.9.202105060958.jar
Change log:
Would this include Washer with light inside? Is this treaten as ambient?? Or what are you refering to, please??
No, this seems to be another light.
Great news, the binding is now part of the official openHAB distribution.
Should be included in next snapshot that will be built next night.
Hi Jonas,
Iâm getting below log when restarting OH3 - any idea?
2021-05-16 10:21:39.720 [ERROR] [al.factory.HomeConnectHandlerFactory] - bundle org.openhab.binding.homeconnect:3.1.0.202105021543 (279)[org.openhab.binding.homeconnect.internal.factory.HomeConnectHandlerFactory(332)] : Error during instantiation of the implementation object
java.lang.IllegalArgumentException: argument type mismatch
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:490) ~[?:?]
at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:316) ~[bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:286) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1000) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:973) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:918) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:216) [org.eclipse.osgi-3.16.200.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:213) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:114) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:48) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:547) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:533) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:656) [org.eclipse.osgi-3.16.200.jar:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:88) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:675) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2556) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:2075) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:2058) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:443) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:301) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1200) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1121) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:928) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:864) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1152) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:114) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:120) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:957) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:936) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:873) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:261) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:496) [org.eclipse.osgi-3.16.200.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:667) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:305) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:554) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:70) [bundleFile:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:421) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) [osgi.core-7.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:945) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:232) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:486) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1781) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.16.200.jar:?]
What is your OH version?
Hi - version is 3.1.0M4
Did you tried the following jar?
Just tested it on a clean installation of openHAB 3.1.0.M4 and it worked.
