Home Energy Meter
Hello
I understand this is a topic that’s been covered a lot however most of the topics are from years ago.
I would hope someone could help with a cost effective way to monitor the total Home Energy Meter?
Was looking for something to clip on the main supply cable and feed in to OH and log the data.
Is the an easy way to do this? If so what equipment should I be looking at? Will it be easy to connect to OH?
Thanks for any help and support
If you are using Zwave, Aeotech makes one. I’ve an older model and it works well.
Shelly 3EM
If you have a PV you should be getting a matching smart meter, most inverters you can connect one to via serial then read Modbus through the inverter.
