we’re using the Homematic binding with homegear. We’ve noticed that sometimes events generated by Homematic components are received by homegear, but ignored by OpenHAB 2.
A PRESS_LONG event is linked to a switch named “tor_ta_freigabe”.
In this example the PRESS_LONG event at 20:54:00 has not been processed by OpenHAB, but the event at 20:55:32 has been processed. It’s not reproducible; most of the time it works, but sometime it doesn’t.
Please have a look at the following logs:
- Homegear:
06/19/17 20:54:00.353 Module HomeMatic BidCoS: Info: PRESS_LONG on channel 1 of HomeMatic BidCoS peer 3 with serial number OEQ0176016 was set to 0x13.
06/19/17 20:54:00.625 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:54:00.898 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:54:01.171 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:54:01.444 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:54:01.716 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:54:01.989 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:54:02.262 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:54:02.535 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:54:02.535 Module HomeMatic BidCoS: Info: PRESS_LONG_RELEASE on channel 1 of HomeMatic BidCoS peer 3 with serial number OEQ0176016 was set to 0x13.
06/19/17 20:55:32.829 Module HomeMatic BidCoS: Info: PRESS_LONG on channel 1 of HomeMatic BidCoS peer 3 with serial number OEQ0176016 was set to 0x14.
06/19/17 20:55:33.101 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:55:33.374 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:55:33.647 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:55:33.920 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:55:34.193 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:55:34.466 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:55:34.739 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:55:35.012 Module HomeMatic BidCoS: Info: Ignoring PRESS_LONG.
06/19/17 20:55:35.012 Module HomeMatic BidCoS: Info: PRESS_LONG_RELEASE on channel 1 of HomeMatic BidCoS peer 3 with serial number OEQ0176016 was set to 0x14.
- OpenHAB:
2017-06-19 20:54:56.228 [ThingUpdatedEvent ] - Thing ‘homematic:GATEWAY-EXTRAS-11ADD6BF:11add6bf:GWE00000000’ has been updated.
2017-06-19 20:54:56.363 [ThingUpdatedEvent ] - Thing ‘homematic:HG-HM-MOD-EM-8:11add6bf:OEQ0176016’ has been updated.
2017-06-19 20:54:56.450 [ThingUpdatedEvent ] - Thing ‘homematic:HG-HM-Sec-Key-S:11add6bf:NEQ0682619’ has been updated.
2017-06-19 20:54:56.605 [ThingUpdatedEvent ] - Thing ‘homematic:HG-HM-RC-Key4-2:11add6bf:NEQ0683927’ has been updated.
2017-06-19 20:55:32.850 [ItemStateChangedEvent ] - tor_ta_freigabe changed from OFF to ON
2017-06-19 20:55:32.877 [ItemCommandEvent ] - Item ‘gl_vsw_freigabe_steuerung’ received command ON
2017-06-19 20:55:32.884 [ItemStateChangedEvent ] - gl_vsw_freigabe_steuerung changed from OFF to ON
2017-06-19 20:55:34.847 [ItemStateChangedEvent ] - tor_ta_freigabe changed from ON to OFF
2017-06-19 20:57:33.215 [ItemCommandEvent ] - Item ‘gl_vsw_freigabe_steuerung’ received command OFF
2017-06-19 20:57:33.227 [ItemStateChangedEvent ] - gl_vsw_freigabe_steuerung changed from ON to OFF
2017-06-19 21:00:56.634 [ThingUpdatedEvent ] - Thing ‘homematic:GATEWAY-EXTRAS-11ADD6BF:11add6bf:GWE00000000’ has been updated.
2017-06-19 21:00:56.840 [ThingUpdatedEvent ] - Thing ‘homematic:HG-HM-MOD-EM-8:11add6bf:OEQ0176016’ has been updated.
2017-06-19 21:00:56.936 [ThingUpdatedEvent ] - Thing ‘homematic:HG-HM-Sec-Key-S:11add6bf:NEQ0682619’ has been updated.
2017-06-19 21:00:57.089 [ThingUpdatedEvent ] - Thing ‘homematic:HG-HM-RC-Key4-2:11add6bf:NEQ0683927’ has been updated.
Any idea what’s going wrong here?
