- Platform information:
- Hardware: Pi4+
- OS: what OS is used and which version
- Java Runtime Environment: Openhabian included
- openHAB version: 3.0
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
ich habe Openhabian installiert und dann die Homegear installation über die gui durchgeführt. Diese endet mit Fehlermeldung. Homegear startet leider nicht. Nach sudo -u homegear homegear erhalte ich folgende Ausgabe:
09/18/21 22:05:22.800 Loading settings from /etc/homegear/main.conf
09/18/21 22:05:22.801 Loading RPC server settings from /etc/homegear/rpcservers.conf
09/18/21 22:05:22.802 Loading RPC client settings from /etc/homegear/rpcclients.conf
09/18/21 22:05:22.802 Debug: hostname of RPC client ExampleClient1 set to myhostname
09/18/21 22:05:22.802 Debug: caFile of RPC client ExampleClient1 set to /path/to/ca-certficate
09/18/21 22:05:22.802 Debug: verifyCertificate of RPC client ExampleClient1 set to 1
09/18/21 22:05:22.802 Debug: forceSSL of RPC client ExampleClient1 set to 0
09/18/21 22:05:22.802 Debug: authType of RPC client ExampleClient1 set to 1
09/18/21 22:05:22.802 Debug: userName of RPC client ExampleClient1 set to myuser
09/18/21 22:05:22.802 Debug: password of RPC client ExampleClient1 was set.
09/18/21 22:05:22.802 Debug: certFile of RPC client ExampleClient1 set to /path/to/client.crt
09/18/21 22:05:22.802 Debug: keyFile of RPC client ExampleClient1 set to /path/to/client.key
09/18/21 22:05:22.802 Debug: retries of RPC client ExampleClient1 set to 3
09/18/21 22:05:22.802 Debug: timeout of RPC client ExampleClient1 set to 15000000
09/18/21 22:05:22.802 Debug: hostname of RPC client ExampleClient2 set to 192.168.178.89
09/18/21 22:05:22.802 Debug: retries of RPC client ExampleClient2 set to 5
09/18/21 22:05:22.802 Debug: timeout of RPC client ExampleClient2 set to 30000000
09/18/21 22:05:22.803 Info: Setting allowed core file size to "4294967295" for user with id 114 and group with id 121.
09/18/21 22:05:22.803 Info: Core file size now is "4294967295".
09/18/21 22:05:22.803 Info: Setting maximum thread priority to "0" for user with id 114 and group with id 121.
09/18/21 22:05:22.803 Info: Maximum thread priority now is "0".
09/18/21 22:05:22.803 Starting Homegear...
09/18/21 22:05:22.803 Homegear version: 0.7.48-3324
09/18/21 22:05:22.803 Determining maximum thread count...
09/18/21 22:05:23.898 Maximum thread count is: 333
09/18/21 22:05:23.906 Info: Backing up database...
09/18/21 22:05:23.968 Initializing database...
09/18/21 22:05:24.465 Homegear instance ID: 0005CC49FD8C3351-A74E1325-EC55-E425-2042-DC1BEBB60270
09/18/21 22:05:24.465 Debug: Loading licensing modules
09/18/21 22:05:24.465 Initializing system variable controller...
09/18/21 22:05:24.467 Debug: Loading family modules
09/18/21 22:05:24.467 Info: Loading family module (type 1) mod_miscellaneous.so
09/18/21 22:05:24.471 Info: Loading settings from /etc/homegear/families/miscellaneous.conf
09/18/21 22:05:24.472 Info: Homegear is (now) running as user with id 114 and group with id 121.
09/18/21 22:05:24.526 Starting script engine server...
09/18/21 22:05:24.551 Script Engine Server: Critical: Directory /var/run/homegear/ does not exist. Please create it before starting Homegear otherwise the script engine won't work.
09/18/21 22:05:24.551 Critical: Cannot start script engine server. Exiting Homegear.
09/18/21 22:05:24.552 Closing database...
09/18/21 22:05:24.552 Debug: Can't execute "COMMIT": cannot commit - no transaction is active
09/18/21 22:05:24.586 Info: Disposing family module mod_miscellaneous.so
09/18/21 22:05:24.586 Debug: Deleting factory pointer of module mod_miscellaneous.so
09/18/21 22:05:24.586 Debug: Closing dynamic library module mod_miscellaneous.so
09/18/21 22:05:24.586 Debug: Dynamic library mod_miscellaneous.so disposed
Es scheint irgendwie an diesem Punkt zu liegen: Critical: Cannot start script engine server. Exiting Homegear.
Ich möchte einfach nur Homegear über das Openhabian GUI installieren…
Weiß jemand Rat?
Danke und Gruß
