I have installed Openhab 2.2, have various Homematic sensors wand want to migrate CCU2 to Opengear.
Registration on opengear under openhabian works fine, I can see the sensors within Openhab, but no messages are sent to the mqtt server even if the mqtt.conf file hat been edited (enabled = true).
As I want to use node-red to migrate my ccu2 programs I need to see the sensors within mqtt.
Rem: Mqtt is running as I can see other sensors like ESP8266 based switches sending data to the message server.
Does anyone have a solution or experienced similar problems ?
