I have updated my IOS devices to the Betaversion of IOS16 including also my apple TV´s which are the “homekit servers”
Now i have issues with getting my items into Apple Homekit… I know IOS16 is a beta version and they changed something in Homekit.
I tried to find out if i can do anything to bring it back to work and checked openhab for some suspisios log entries.
i saw that there is a newer version of the homekit addon is available and tried to update…
now i have the issue that i have two instances of homekit running and i am not able to uninstall the old one… it always cames back after restart of OH2.
openhab> bundle:list | grep -i homekit
163 x Active x 80 x 2.4.0 x HomeKit Integration
307 x Active x 80 x 2.5.12 x openHAB Add-ons :: Bundles :: IO :: Homekit
the Homekit integration is always coming back…
Also i have now two config items in PaperUI
I occasionally get multiple versions of bundles hanging around, and here’s what normally fixes the problem for me:
I assume you’re doing a bundle:uninstall 163 (based on your screenshot), right?
The first thing I’d do is check your addons/ directory to make sure you don’t have a version sitting in there. Then, I would try clearing your openhab cache and restarting. The steps for doing that vary depending on how you’ve installed openhab, so do a search here for “clear cache” if you’re not familiar with the process.
Hopefully that will fix the problem. If not, let us know!
I did this two or three times… but it is still the same as before…
I also tried to rename the homekit.cfg to homekit.cfg.bak in Services so that OH2 is not reading the config file…
