Thanks for prompt reply! Iβm running 2.5.0 build 1589.
Iβve followed your instructions but when I run βfeature:install openhab-misc-homekit-testβ Iβm promptly disconnected from console and after a while I see following logs (no logs before this)
==> /srv/openhab2-logs/events.log <==
2019-05-12 23:24:24.746 [thome.event.ExtensionEvent] - Extension βmisc-homekit-testβ has been uninstalled.
==> /var/log/syslog <==
May 12 23:24:25 ambrogio karaf[7072]: Exception in thread βnioEventLoopGroup-2-1β java.lang.NoClassDefFoundError: io/netty/util/concurrent/DefaultPromise$2
May 12 23:24:25 ambrogio karaf[7072]: #011at io.netty.util.concurrent.DefaultPromise.notifyListeners(DefaultPromise.java:589)
May 12 23:24:25 ambrogio karaf[7072]: #011at io.netty.util.concurrent.DefaultPromise.setSuccess(DefaultPromise.java:397)
May 12 23:24:25 ambrogio karaf[7072]: #011at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:151)
May 12 23:24:25 ambrogio karaf[7072]: #011at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:137)
May 12 23:24:25 ambrogio karaf[7072]: #011at java.lang.Thread.run(Thread.java:748)
May 12 23:24:25 ambrogio karaf[7072]: Caused by: java.lang.ClassNotFoundException: io.netty.util.concurrent.DefaultPromise$2 cannot be found by wrap_file__var_lib_openhab2_tmp_mvn_io_netty_netty-all_4.0.32.Final_netty-all-4.0.32.Final.jar_0.0.0
May 12 23:24:25 ambrogio karaf[7072]: #011at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:484)
May 12 23:24:25 ambrogio karaf[7072]: #011at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
May 12 23:24:25 ambrogio karaf[7072]: #011at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
May 12 23:24:25 ambrogio karaf[7072]: #011at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
May 12 23:24:25 ambrogio karaf[7072]: #011at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
May 12 23:24:25 ambrogio karaf[7072]: #011β¦ 5 more
May 12 23:24:25 ambrogio karaf[7072]: Exception in thread βnioEventLoopGroup-3-2β Exception in thread βnioEventLoopGroup-3-5β java.lang.NoClassDefFoundError: io/netty/util/concurrent/DefaultPromise$2
May 12 23:24:25 ambrogio karaf[7072]: Exception in thread βnioEventLoopGroup-2-3β #011at io.netty.util.concurrent.DefaultPromise.notifyListeners(DefaultPromise.java:589)
May 12 23:24:25 ambrogio karaf[7072]: Exception in thread βnioEventLoopGroup-3-6β Exception in thread βnioEventLoopGroup-3-8β java.lang.NoClassDefFoundError: io/netty/util/concurrent/DefaultPromise$2
May 12 23:24:25 ambrogio karaf[7072]: java.lang.NoClassDefFoundError: io/netty/util/concurrent/DefaultPromise$2
May 12 23:24:25 ambrogio karaf[7072]: Exception in thread βnioEventLoopGroup-2-4β Exception in thread βnioEventLoopGroup-3-7β #011at io.netty.util.concurrent.DefaultPromise.notifyListeners(DefaultPromise.java:589)
May 12 23:24:25 ambrogio karaf[7072]: Exception in thread βnioEventLoopGroup-3-3β #011at io.netty.util.concurrent.DefaultPromise.notifyListeners(DefaultPromise.java:589)
May 12 23:24:25 ambrogio karaf[7072]: Exception in thread βnioEventLoopGroup-3-1β Exception in thread βnioEventLoopGroup-2-6β Exception in thread βnioEventLoopGroup-2-8β Exception in thread βnioEventLoopGroup-2-7β Exception in thread βnioEventLoopGroup-2-2β Exception in thread βnioEventLoopGroup-3-4β java.lang.NoClassDefFoundError: io/netty/util/concurrent/DefaultPromise$2
May 12 23:24:25 ambrogio karaf[7072]: Exception in thread βnioEventLoopGroup-2-5β #011at io.netty.util.concurrent.DefaultPromise.notifyListeners(DefaultPromise.java:589)
