when I controll it with the openHAB app (from 0% to 11%), I get this in event.log (Roller_EG_Buro ist the openHAB item, HK_Roller_EG_Buro ist the HomeKit Item with the same channel). In This case, the roller shuter works correctly, and goes to 11%:
2020-09-19 10:20:57.441 [ome.event.ItemCommandEvent] - Item 'Roller_EG_Buro' received command 11
2020-09-19 10:20:57.443 [nt.ItemStatePredictedEvent] - Roller_EG_Buro predicted to become 11
2020-09-19 10:20:57.463 [vent.ItemStateChangedEvent] - Roller_EG_Buro changed from 97 to 11
2020-09-19 10:20:59.089 [vent.ItemStateChangedEvent] - HK_Roller_EG_Buro changed from 97 to 4
2020-09-19 10:20:59.092 [vent.ItemStateChangedEvent] - Roller_EG_Buro changed from 11 to 4
When I do the same with the Home app (from 0% to 11%), then I get this in the event.log. But when I start, the Home app shows me â8% openâ, despite the shutter is realy in position 0%:
2020-09-19 10:27:11.928 [ome.event.ItemCommandEvent] - Item 'HK_Roller_EG_Buro' received command 14
2020-09-19 10:27:11.930 [nt.ItemStatePredictedEvent] - HK_Roller_EG_Buro predicted to become 14
2020-09-19 10:27:11.942 [vent.ItemStateChangedEvent] - HK_Roller_EG_Buro changed from 8 to 14
2020-09-19 10:27:12.238 [ome.event.ItemCommandEvent] - Item 'HK_Roller_EG_Buro' received command 16
2020-09-19 10:27:12.241 [nt.ItemStatePredictedEvent] - HK_Roller_EG_Buro predicted to become 16
2020-09-19 10:27:12.260 [vent.ItemStateChangedEvent] - HK_Roller_EG_Buro changed from 14 to 16
2020-09-19 10:27:12.703 [vent.ItemStateChangedEvent] - fboxUptime changed from 2447 to 2513
2020-09-19 10:27:13.137 [ome.event.ItemCommandEvent] - Item 'HK_Roller_EG_Buro' received command 14
2020-09-19 10:27:13.139 [nt.ItemStatePredictedEvent] - HK_Roller_EG_Buro predicted to become 14
2020-09-19 10:27:13.162 [vent.ItemStateChangedEvent] - HK_Roller_EG_Buro changed from 16 to 14
2020-09-19 10:27:13.439 [ome.event.ItemCommandEvent] - Item 'HK_Roller_EG_Buro' received command 12
2020-09-19 10:27:13.444 [nt.ItemStatePredictedEvent] - HK_Roller_EG_Buro predicted to become 12
2020-09-19 10:27:13.469 [vent.ItemStateChangedEvent] - HK_Roller_EG_Buro changed from 14 to 12
2020-09-19 10:27:13.895 [ome.event.ItemCommandEvent] - Item 'HK_Roller_EG_Buro' received command 10
2020-09-19 10:27:13.898 [nt.ItemStatePredictedEvent] - HK_Roller_EG_Buro predicted to become 10
2020-09-19 10:27:13.921 [vent.ItemStateChangedEvent] - HK_Roller_EG_Buro changed from 12 to 10
2020-09-19 10:27:14.820 [ome.event.ItemCommandEvent] - Item 'HK_Roller_EG_Buro' received command 11
2020-09-19 10:27:14.822 [nt.ItemStatePredictedEvent] - HK_Roller_EG_Buro predicted to become 11
2020-09-19 10:27:14.843 [vent.ItemStateChangedEvent] - HK_Roller_EG_Buro changed from 10 to 11
2020-09-19 10:27:16.480 [vent.ItemStateChangedEvent] - HK_Roller_EG_Buro changed from 11 to 4
2020-09-19 10:27:16.484 [vent.ItemStateChangedEvent] - Roller_EG_Buro changed from 8 to 4
There are many updates during moving the slider. HomeKit does already some updates during moving the slider.
When openhab/homekit are finished with this action, the rollershutter stands at position 11%, but the HomeKit app shows 4%. So I think the controll of the rollershutter is working now, but the position showed is not correct.
So, I think its not a homekit issue, but an zwave one. I have to check the zwave configuration first, since the position showed is also not correct in the openhab app. I did not regocnice this yet.
