i use homekit with openhab and it’s work fine with wifi. but i would like use homekit when i 'm not in my house, so i open all the port in my adslbox for openhab (create a dmz) and in the configuration (paperui) i put my ip public adress (i try 82.246.X.X:8080 or 82.246.X.X) but it’s not work.
do you know if homekit works in 4g (outside house) and how configure it.
Homekit works away from home - if you have a homepod or recent model Apple TV at the house and logged into the same iCloud account as your phone. Apple calls this a “home hub”
This can also work with certain iPads if you do the right settings.
This is a bad idea. I suggest that you use a VPN instead of just punching a hole though your firewall. That bot in not secured and you will get hacked eventually.
