i don’t know if this is an error or just not implemented.
If i try to expose an Group:Dimmer:AVG Item vie the Homekit Plugin i am only seeing a switch iOS.
Here is my item deifnition:
Group:Dimmer:AVG H_Lamps_D "All Lamps Dimmer" ["Lighting"] <dimmablelight>
This seems to be correct, as i can see the following export via http://:9124/accessories:
"accessories": [{
"aid": 1,
"services": [{
"iid": 1,
"type": "0000003E-0000-1000-8000-0026BB765291",
"characteristics": [{
"iid": 2,
"type": "00000023-0000-1000-8000-0026BB765291",
"perms": ["pr"],
"format": "string",
"events": false,
"bonjour": false,
"description": "Name of the accessory",
"value": "openHAB",
"maxLen": 255
}, {69696
"iid": 3,
"type": "00000020-0000-1000-8000-0026BB765291",
"perms": ["pr"],
"format": "string",
"events": false,
"bonjour": false,
"description": "The name of the manufacturer",
"value": "openHAB",
"maxLen": 255
"iid": 4,
"type": "00000021-0000-1000-8000-0026BB765291",
"perms": ["pr"],
"format": "string",
"events": false,
"bonjour": false,
"description": "The name of the model",
"value": "2.0.0.201609240823",
"maxLen": 255
"iid": 5,
"type": "00000030-0000-1000-8000-0026BB765291",
"perms": ["pr"],
"format": "string",
"events": false,
"bonjour": false,
"description": "The serial number of the accessory",
"value": "none",
"maxLen": 255
"iid": 6,
"type": "00000014-0000-1000-8000-0026BB765291",
"perms": ["pw"],
"format": "bool",
"events": false,
"bonjour": false,
"description": "Identifies the accessory via a physical action on the accessory"
"aid": 534983677,
"services": [{
"iid": 1,
"iid": 2,
"perms": ["pr"],
"format": "string",
"events": false,
"bonjour": false,
"value": "All Lamps Dimmer",
"maxLen": 255
"iid": 3,
"perms": ["pr"],
"format": "string",
"events": false,
"bonjour": false,
"value": "none",
"maxLen": 255
"iid": 4,
"perms": ["pr"],
"format": "string",
"events": false,
"bonjour": false,
"value": "none",
"maxLen": 255
"iid": 5,
"perms": ["pr"],
"format": "string",
"events": false,
"bonjour": false,
"value": "none",
"maxLen": 255
"iid": 6,
"perms": ["pw"],
"format": "bool",
"events": false,
"bonjour": false,
"iid": 7,
"type": "00000043-0000-1000-8000-0026BB765291",
"iid": 8,
"perms": ["pr"],
"format": "string",
"events": false,
"bonjour": false,
"maxLen": 255
"iid": 9,
"type": "00000025-0000-1000-8000-0026BB765291",
"perms": ["pw", "pr", "ev"],
"format": "bool",
"events": false,
"bonjour": false,
"description": "Turn on and off",
"value": true
