I installed OpenHab 2.0.0 (Release Build) on a Debian Jessie board (A20-OLinuXino-Lime2)
I try to pair from an iOS device using Homekit and get a NullPointerException error:
17:47:46.096 [ERROR] [lfe.hap.impl.connections.HttpSession] - Could not handle request
java.lang.NullPointerException
at com.beowulfe.hap.characteristics.FloatCharacteristic.getValue(FloatCharacteristic.java:72)[211:org.openhab.io.homekit:2.0.0]
at com.beowulfe.hap.characteristics.BaseCharacteristic.makeBuilder(BaseCharacteristic.java:71)[211:org.openhab.io.homekit:2.0.0]
at com.beowulfe.hap.characteristics.FloatCharacteristic.makeBuilder(FloatCharacteristic.java:48)[211:org.openhab.io.homekit:2.0.0]
at com.beowulfe.hap.characteristics.BaseCharacteristic.toJson(BaseCharacteristic.java:61)[211:org.openhab.io.homekit:2.0.0]
at com.beowulfe.hap.impl.json.AccessoryController.toJson(AccessoryController.java:73)[211:org.openhab.io.homekit:2.0.0]
at com.beowulfe.hap.impl.json.AccessoryController.listing(AccessoryController.java:39)[211:org.openhab.io.homekit:2.0.0]
at com.beowulfe.hap.impl.connections.HttpSession.handleAuthenticatedRequest(HttpSession.java:70)[211:org.openhab.io.homekit:2.0.0]
at com.beowulfe.hap.impl.connections.ConnectionImpl.doHandleRequest(ConnectionImpl.java:51)[211:org.openhab.io.homekit:2.0.0]
at com.beowulfe.hap.impl.connections.ConnectionImpl.handleRequest(ConnectionImpl.java:46)[211:org.openhab.io.homekit:2.0.0]
at com.beowulfe.hap.impl.http.impl.AccessoryHandler.channelRead0(AccessoryHandler.java:47)[211:org.openhab.io.homekit:2.0.0]
at com.beowulfe.hap.impl.http.impl.AccessoryHandler.channelRead0(AccessoryHandler.java:15)[211:org.openhab.io.homekit:2.0.0]
at io.netty.channel.SimpleChannelInboundHandler.channelRead(SimpleChannelInboundHandler.java:105)[211:org.openhab.io.homekit:2.0.0]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:308)[211:org.openhab.io.homekit:2.0.0]
at io.netty.channel.AbstractChannelHandlerContext.access$600(AbstractChannelHandlerContext.java:32)[211:org.openhab.io.homekit:2.0.0]
at io.netty.channel.AbstractChannelHandlerContext$7.run(AbstractChannelHandlerContext.java:299)[211:org.openhab.io.homekit:2.0.0]
at io.netty.util.concurrent.DefaultEventExecutor.run(DefaultEventExecutor.java:36)[211:org.openhab.io.homekit:2.0.0]
at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112)[211:org.openhab.io.homekit:2.0.0]
at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:137)[211:org.openhab.io.homekit:2.0.0]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
The same configuration was working with openhab2 Beta4. I test with Beta5 and I got the same error.
Re-installing the beta4 after beta5 solved the problem.
Should I rollback from “Release Build” to beta4 to get something that works ?
What could I try else ?
