efka
(efka)
February 24, 2017, 5:54pm
1
Hello.
I finally got homekit working with my newly bought raspberry. Everything worked fine. I installed all device i have and are compatible but somehow now the devices are shown as “not answering” in the ios homeapp and i cant control them anymore. In the PaperUI i see the right values / states of my items but somehow they are not connected to homekit anymore.
I also tried to restart the raspberry in hope that the reboot makes it working again but it still dont work.
bundle:restart with the homekit id also didnt helped.
Did i miss something that needed to be done? I use the openhabian release from here
hamwong
(Ham Wong)
February 24, 2017, 6:18pm
2
when issue happen, need to restart openhab service,
for me, sometimes happen in hours, sometimes in days.
efka
(efka)
February 24, 2017, 6:19pm
3
by sudo service openhab restart ?
Marty56
(Martin)
February 24, 2017, 7:06pm
4
I am experiencing the same behavior under windows and have given up using it.
efka
(efka)
February 27, 2017, 10:31pm
6
Still havent fully fixed it. Atm i’m already struggling at pairing my iphone with the openHAB Homekit addon.
Here are the whole logs maybe someone know what i need to do.
Tried clearPairing. clearPairing then reinstall. Restarting openHAB between uninstall and reinstall but i’m at the end of ideas.
2017-02-27 23:25:08.022 [INFO ] [ore.internal.i18n.LocaleProviderImpl] - Locale set to de_DE
2017-02-27 23:25:13.792 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'homekit.items'
2017-02-27 23:25:14.094 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2017-02-27 23:25:17.454 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sonos.rules'
2017-02-27 23:25:19.118 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.sitemap'
2017-02-27 23:25:19.619 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'netatmo.things'
2017-02-27 23:25:19.689 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sonos.things'
2017-02-27 23:25:21.964 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2017-02-27 23:25:24.112 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-02-27 23:25:24.807 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-02-27 23:25:25.351 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-02-27 23:25:31.299 [INFO ] [b.core.service.AbstractActiveService] - FritzboxTr064 Refresh Service has been started
2017-02-27 23:25:31.378 [INFO ] [b.core.service.AbstractActiveService] - FritzBox refresh Service has been started
2017-02-27 23:25:31.385 [INFO ] [ng.fritzbox.internal.FritzboxBinding] - Fritzbox conditional deActivate: false
2017-02-27 23:25:32.301 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2017-02-27 23:25:32.446 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2017-02-27 23:26:33.868 [WARN ] [nhab.io.homekit.internal.HomekitImpl] - Could not find existing MAC in org.eclipse.smarthome.storage.json.JsonStorage. Generating new MAC. This will require re-pairing of iOS devices.
2017-02-27 23:26:36.542 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory openHAB
2017-02-27 23:26:37.047 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Kueche Steckdose
2017-02-27 23:26:37.047 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Bound homekit listener to /0:0:0:0:0:0:0:0:9123
2017-02-27 23:26:37.062 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.068 [INFO ] [ap.impl.jmdns.JmdnsHomekitAdvertiser] - Advertising accessory openHAB
2017-02-27 23:26:37.070 [INFO ] [ap.impl.jmdns.JmdnsHomekitAdvertiser] - Registering _hap._tcp.local. on port 9123
2017-02-27 23:26:37.077 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Jugend Steckdose
2017-02-27 23:26:37.080 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.081 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Bad Steckdose
2017-02-27 23:26:37.085 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.086 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Wohn Steckdose
2017-02-27 23:26:37.089 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.090 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Schlaf Steckdose
2017-02-27 23:26:37.094 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.095 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Temperatur
2017-02-27 23:26:37.105 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.106 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Temperatur
2017-02-27 23:26:37.111 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.112 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Temperatur
2017-02-27 23:26:37.118 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.119 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Leistung
2017-02-27 23:26:37.129 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.129 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Leistung
2017-02-27 23:26:37.137 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.137 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Leistung
2017-02-27 23:26:37.145 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.146 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Leistung
2017-02-27 23:26:37.155 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.156 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Leistung
2017-02-27 23:26:37.165 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.166 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Strom
2017-02-27 23:26:37.175 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.176 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Strom
2017-02-27 23:26:37.186 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.187 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Strom
2017-02-27 23:26:37.198 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.199 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Strom
2017-02-27 23:26:37.211 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:26:37.211 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Strom
2017-02-27 23:26:37.224 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.357 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory openHAB
2017-02-27 23:27:38.387 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Kueche Steckdose
2017-02-27 23:27:38.392 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Bound homekit listener to /0:0:0:0:0:0:0:0:9124
2017-02-27 23:27:38.394 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.395 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Jugend Steckdose
2017-02-27 23:27:38.396 [INFO ] [ap.impl.jmdns.JmdnsHomekitAdvertiser] - Advertising accessory openHAB
2017-02-27 23:27:38.398 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.398 [INFO ] [ap.impl.jmdns.JmdnsHomekitAdvertiser] - Registering _hap._tcp.local. on port 9124
2017-02-27 23:27:38.399 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Bad Steckdose
2017-02-27 23:27:38.413 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.415 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Wohn Steckdose
2017-02-27 23:27:38.420 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.421 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Schlaf Steckdose
2017-02-27 23:27:38.425 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.426 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Temperatur
2017-02-27 23:27:38.429 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.430 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Temperatur
2017-02-27 23:27:38.434 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.435 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Temperatur
2017-02-27 23:27:38.438 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.439 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Leistung
2017-02-27 23:27:38.443 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.444 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Leistung
2017-02-27 23:27:38.449 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.450 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Leistung
2017-02-27 23:27:38.455 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.456 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Leistung
2017-02-27 23:27:38.461 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.462 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Leistung
2017-02-27 23:27:38.468 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.468 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Strom
2017-02-27 23:27:38.475 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.476 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Strom
2017-02-27 23:27:38.483 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.484 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Strom
2017-02-27 23:27:38.491 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.491 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Strom
2017-02-27 23:27:38.498 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:27:38.499 [INFO ] [com.beowulfe.hap.HomekitRoot ] - Added accessory Strom
2017-02-27 23:27:38.507 [INFO ] [pl.http.impl.NettyHomekitHttpService] - Resetting connections
2017-02-27 23:29:06.833 [TRACE] [pl.http.impl.NettyHomekitHttpService] - READ UnpooledUnsafeDirectByteBuf(ridx: 0, widx: 132, cap: 1024) [/192.168.178.45:49194]:
00000000 50 4F 53 54 20 2F 70 61 69 72 2D 73 65 74 75 70 POST /pair-setup
00000010 20 48 54 54 50 2F 31 2E 31 0D 0A 48 6F 73 74 3A HTTP/1.1..Host:
00000020 20 6F 70 65 6E 48 41 42 5C 30 33 32 28 32 29 2E openHAB\032(2).
00000030 5F 68 61 70 2E 5F 74 63 70 2E 6C 6F 63 61 6C 0D _hap._tcp.local.
00000040 0A 43 6F 6E 74 65 6E 74 2D 4C 65 6E 67 74 68 3A .Content-Length:
00000050 20 36 0D 0A 43 6F 6E 74 65 6E 74 2D 54 79 70 65 6..Content-Type
00000060 3A 20 61 70 70 6C 69 63 61 74 69 6F 6E 2F 70 61 : application/pa
00000070 69 72 69 6E 67 2B 74 6C 76 38 0D 0A 0D 0A 00 01 iring+tlv8......
00000080 00 06 01 01 ....
2017-02-27 23:29:06.837 [INFO ] [.hap.impl.http.impl.AccessoryHandler] - New homekit connection from /192.168.178.45:49194
2017-02-27 23:29:06.890 [INFO ] [ulfe.hap.impl.pairing.PairingManager] - Starting pair for openHAB
2017-02-27 23:29:09.189 [INFO ] [ap.impl.http.HomekitClientConnection] - 200 /pair-setup
2017-02-27 23:29:09.208 [TRACE] [pl.http.impl.NettyHomekitHttpService] - WRITE UnpooledUnsafeDirectByteBuf(ridx: 0, widx: 513, cap: 1024) [/192.168.178.45:49194]:
00000000 48 54 54 50 2F 31 2E 31 20 32 30 30 20 4F 4B 0D HTTP/1.1 200 OK.
00000010 0A 43 6F 6E 74 65 6E 74 2D 74 79 70 65 3A 20 61 .Content-type: a
00000020 70 70 6C 69 63 61 74 69 6F 6E 2F 70 61 69 72 69 pplication/pairi
00000030 6E 67 2B 74 6C 76 38 0D 0A 43 6F 6E 74 65 6E 74 ng+tlv8..Content
00000040 2D 4C 65 6E 67 74 68 3A 20 34 30 39 0D 0A 43 6F -Length: 409..Co
00000050 6E 6E 65 63 74 69 6F 6E 3A 20 6B 65 65 70 2D 61 nnection: keep-a
00000060 6C 69 76 65 0D 0A 0D 0A 06 01 02 02 10 DD 8B 9B live............
00000070 60 B9 B3 5E 93 2E 3D A1 0C 4B 7F 83 A0 03 FF 67 `..^..=..K.....g
00000080 46 31 45 DD 95 26 7E 72 0B 84 EC BA 42 84 92 A3 F1E..&~r....B...
00000090 03 8E 5D F4 82 E2 C0 5A 90 06 FA 05 29 FA FE 80 ..]....Z....)...
000000A0 AB CE F5 CB 5B 3E 21 45 66 03 2D 5B 3E 38 1E C3 ....[>!Ef.-[>8..
000000B0 E2 3E 0E BA 96 5D DB 54 5F 2B B5 1B 69 7D BB 6D .>...].T_+..i}.m
000000C0 8C A2 DA B3 DB 7E F9 8D 5D 69 99 51 EC 74 53 09 .....~..]i.Q.tS.
000000D0 CE E2 69 DA A0 86 D7 B7 42 68 CF DC D9 1D 3A F2 ..i.....Bh....:.
000000E0 0F 86 A8 15 AE 17 8B 98 1A 68 B6 63 A1 50 AD DF .........h.c.P..
000000F0 A0 BE 96 47 7B C1 2E 31 7C 7A B8 0F D1 55 3C 17 ...G{..1|z...U<.
00000100 45 47 F2 27 24 44 EB 0B C6 3F 0B F4 E2 51 63 0E EG.'$D...?...Qc.
00000110 ED 8D 3E 72 3C 87 22 D7 2D B6 D8 60 47 2C 83 91 ..>r<.".-..`G,..
00000120 1B 2B 0E 4C D3 E1 57 AA B9 A5 E9 19 F6 82 3E 32 .+.L..W.......>2
00000130 47 52 C0 97 64 65 C8 ED EA A1 2B 43 1B 44 73 B8 GR..de....+C.Ds.
00000140 F2 B1 FB 91 4B 7E E2 08 F6 6E 12 F4 11 67 A2 E3 ....K~...n...g..
00000150 0F 82 C7 53 D2 06 8B 75 72 20 51 ED 71 82 7A D6 ...S...ur Q.q.z.
00000160 03 C1 08 5D 8E C5 19 CC 9D 2F 0E B9 25 05 97 F7 ...]...../..%...
00000170 20 B0 F8 16 4D AE E4 25 0B F1 AC 7D B8 F4 03 81 ...M..%...}....
00000180 39 0D 9D F7 B5 9B 48 60 6A 19 50 C7 0A 54 AC 3B 9.....H`j.P..T.;
00000190 26 DE B2 95 8E EE 5A 6B 22 CC D9 01 08 07 22 04 &.....Zk".....".
000001A0 5B 58 F4 A2 F4 51 92 77 37 2E 47 57 E3 6F 95 88 [X...Q.w7.GW.o..
000001B0 9B AE A1 7A 6D 1D F3 B2 12 1C 75 B3 62 E6 18 A2 ...zm.....u.b...
000001C0 2B 3A 49 F6 6F 8B 68 2D 3A 7D 12 2A 12 9F 38 0F +:I.o.h-:}.*..8.
000001D0 BA 55 32 CE 66 40 0E 6C 75 9A C0 D4 3F 85 89 0A .U2.f@.lu...?...
000001E0 5E 3B 7C E6 36 AA 19 DD 91 3F A4 FB 8C 41 A8 6E ^;|.6....?...A.n
000001F0 7B AE 0D AD 84 36 E4 8F 5B 01 01 96 E1 FD D3 DE {....6..[.......
00000200 A2 .
2017-02-27 23:29:10.561 [TRACE] [pl.http.impl.NettyHomekitHttpService] - READ UnpooledUnsafeDirectByteBuf(ridx: 0, widx: 585, cap: 1024) [/192.168.178.45:49194]:
00000050 20 34 35 37 0D 0A 43 6F 6E 74 65 6E 74 2D 54 79 457..Content-Ty
00000060 70 65 3A 20 61 70 70 6C 69 63 61 74 69 6F 6E 2F pe: application/
00000070 70 61 69 72 69 6E 67 2B 74 6C 76 38 0D 0A 0D 0A pairing+tlv8....
00000080 06 01 03 03 FF 03 27 2E 91 70 94 98 0B 0C 13 64 ......'..p.....d
00000090 89 3F F1 8B F5 2D 1A 43 DE DF AB 0A 2C 79 45 C9 .?...-.C....,yE.
000000A0 78 7E 66 4D E0 E8 A2 B5 27 D9 94 45 0B 70 C7 21 x~fM....'..E.p.!
000000B0 2A D9 52 EE 95 B6 2F E7 CB FC 87 86 86 96 8B 5F *.R.../........_
000000C0 5B 88 CC 5A 33 32 B8 72 DA CE FE 48 F0 89 2D 53 [..Z32.r...H..-S
000000D0 A6 8A 3D 79 21 84 CB 77 F3 F5 63 24 AE 5E 58 D1 ..=y!..w..c$.^X.
000000E0 C4 B3 70 F3 5E A3 32 7E CE E2 8E 29 29 E5 DF 3E ..p.^.2~...))..>
000000F0 14 D6 F6 C4 A6 15 7D B8 1B A0 44 93 D4 EE C0 AE ......}...D.....
00000100 EE FC 3C 1B 7A F3 B2 5E 92 82 14 01 E3 15 08 3F ..<.z..^.......?
00000110 48 66 FC 44 5F 30 86 3C 49 4D 38 BB C3 9D DA FB Hf.D_0.<IM8.....
00000120 CB 94 02 9B 87 61 18 F1 21 D1 78 7C 73 8C 1E 4E .....a..!.x|s..N
00000130 3C 9C 91 24 F7 50 D4 F4 00 02 A1 56 88 1B 69 D3 <..$.P.....V..i.
00000140 31 54 C9 F9 F4 4D B0 E5 80 60 E2 86 DD A7 3A 7B 1T...M...`....:{
00000150 9B 7B A8 15 6E 4E 03 AD 4A 59 3A 7D 0B 38 EB A4 .{..nN..JY:}.8..
00000160 2B 68 51 8A A8 68 8D 6A 25 D5 06 31 F4 45 ED 64 +hQ..h.j%..1.E.d
00000170 E7 4B 38 AB BF C6 73 19 63 F5 60 D1 D7 9B EA F8 .K8...s.c.`.....
00000180 87 51 CE DC 03 81 F0 6A A7 67 8A 1B B8 CF 66 8A .Q.....j.g....f.
00000190 1B 59 6E 75 BF 12 B2 69 62 AD 28 FE 85 98 89 2D .Ynu...ib.(....-
000001A0 15 EB 0F A2 8E 31 64 34 26 DA 11 A3 36 72 C7 1E .....1d4&...6r..
000001B0 38 8F 53 80 9F 3A CB C3 53 2A 4B 2A 05 CC 05 B3 8.S..:..S*K*....
000001C0 E2 D2 60 70 A7 95 9A 8D 43 AD 16 57 BA DD 2B 11 ..`p....C..W..+.
000001D0 F6 64 22 F2 14 4D D8 F6 1B 44 52 04 D1 D0 67 38 .d"..M...DR...g8
000001E0 24 03 15 E1 8B 4D 79 55 FA ED AA FF 2C 75 87 EF $....MyU....,u..
000001F0 3F 5E 73 17 C3 50 AA 55 E9 27 17 F3 92 80 47 D4 ?^s..P.U.'....G.
00000200 94 9C 6C 5E DE B6 30 04 40 D3 EC 71 3D 3C E9 B8 ..l^..0.@..q=<..
00000210 47 62 EF 28 F0 89 92 A9 EC 20 AF A3 74 FE C1 1D Gb.(..... ..t...
00000220 FC FF D1 EA E4 BF FA 6E D6 C9 7C D8 E4 10 70 31 .......n..|...p1
00000230 9B 6C 30 7A 1B 8C 5C 8D 3F D8 67 19 18 4D A6 7D .l0z..\.?.g..M.}
00000240 C6 B1 3F E0 D2 40 C6 54 7F ..?..@.T.
2017-02-27 23:29:10.564 [DEBUG] [ulfe.hap.impl.pairing.PairingManager] - Entering second stage of pair for openHAB
2017-02-27 23:29:12.843 [INFO ] [ap.impl.http.HomekitClientConnection] - 200 /pair-setup
2017-02-27 23:29:12.846 [TRACE] [pl.http.impl.NettyHomekitHttpService] - WRITE UnpooledUnsafeDirectByteBuf(ridx: 0, widx: 172, cap: 256) [/192.168.178.45:49194]:
00000040 2D 4C 65 6E 67 74 68 3A 20 36 39 0D 0A 43 6F 6E -Length: 69..Con
00000050 6E 65 63 74 69 6F 6E 3A 20 6B 65 65 70 2D 61 6C nection: keep-al
00000060 69 76 65 0D 0A 0D 0A 06 01 04 04 40 23 49 8E BE ive........@#I..
00000070 EE 33 74 EE 70 10 05 C9 D1 32 D6 C6 66 88 13 A3 .3t.p....2..f...
00000080 77 AE 75 99 60 58 D1 53 B6 E9 22 FB 4B A4 08 3C w.u.`X.S..".K..<
00000090 F3 BE E1 EA 36 90 76 59 8E 01 E2 A1 C4 4F 9D F7 ....6.vY.....O..
000000A0 F3 D0 80 C3 63 BF F1 52 F4 26 E7 34 ....c..R.&.4
2017-02-27 23:29:12.937 [TRACE] [pl.http.impl.NettyHomekitHttpService] - READ UnpooledUnsafeDirectByteBuf(ridx: 0, widx: 287, cap: 1024) [/192.168.178.45:49194]:
00000050 20 31 35 39 0D 0A 43 6F 6E 74 65 6E 74 2D 54 79 159..Content-Ty
00000080 05 9A 40 EE 0C 49 BC C8 4B 05 02 CB 42 12 D9 F8 ..@..I..K...B...
00000090 3F AF 2F F7 04 B9 E6 1B 37 99 76 84 13 C3 63 27 ?./.....7.v...c'
000000A0 E5 0B 2B 9E A1 16 C0 F7 8C 27 28 23 65 82 AB 81 ..+......'(#e...
000000B0 5E AD 07 AB F3 5A 1A 24 80 5B EC 12 42 13 DD DA ^....Z.$.[..B...
000000C0 31 0B 18 51 A2 79 8E BC 7B DD 03 FE AD CF C0 D1 1..Q.y..{.......
000000D0 35 AB CB 2B 8B A9 9D 77 EB B8 BD 42 E0 60 41 2F 5..+...w...B.`A/
000000E0 40 E7 51 9F 44 57 F7 86 23 68 9D D5 A3 62 6C 6D @.Q.DW..#h...blm
000000F0 81 3E E6 9F 78 A9 2F 2B E9 71 9C F9 FE 33 58 80 .>..x./+.q...3X.
00000100 33 92 43 C2 5A 15 BB B3 25 0F B0 8B B8 B5 95 BB 3.C.Z...%.......
00000110 F1 38 C9 DB 50 7C 3E B3 4A 6E F7 11 06 01 05 .8..P|>.Jn.....
2017-02-27 23:29:12.940 [DEBUG] [ulfe.hap.impl.pairing.PairingManager] - Entering third stage of pair for openHAB
2017-02-27 23:29:13.051 [INFO ] [ap.impl.jmdns.JmdnsHomekitAdvertiser] - Re-creating service due to change in discoverability to false
2017-02-27 23:29:15.056 [INFO ] [ap.impl.jmdns.JmdnsHomekitAdvertiser] - Registering _hap._tcp.local. on port 9124
2017-02-27 23:29:17.679 [INFO ] [ap.impl.http.HomekitClientConnection] - 200 /pair-setup
2017-02-27 23:29:17.684 [TRACE] [pl.http.impl.NettyHomekitHttpService] - WRITE UnpooledUnsafeDirectByteBuf(ridx: 0, widx: 244, cap: 256) [/192.168.178.45:49194]:
00000040 2D 4C 65 6E 67 74 68 3A 20 31 34 30 0D 0A 43 6F -Length: 140..Co
00000060 6C 69 76 65 0D 0A 0D 0A 06 01 06 05 87 AE 66 A8 live..........f.
00000070 0D EB A7 B3 D5 62 2D 60 CD 6A 67 93 6F 7B 0B 27 .....b-`.jg.o{.'
00000080 22 42 D7 6E 2A E4 13 95 87 77 A7 00 C9 52 82 06 "B.n*....w...R..
00000090 E9 66 EA 88 7A CA 7D E9 52 BB 2B 05 0C FC 4A 8B .f..z.}.R.+...J.
000000A0 60 7D 6E 23 55 E4 42 EB 27 80 B2 03 1A C1 A2 A8 `}n#U.B.'.......
000000B0 84 7D 1B F9 64 B5 80 73 84 17 AD 30 14 CB 87 AF .}..d..s...0....
000000C0 59 33 21 A3 F0 4E 39 66 DA F1 9E FB DF D1 E5 40 Y3!..N9f.......@
000000D0 02 C3 A1 F4 3B EE 49 F8 0A BD A1 2D D3 12 45 C8 ....;.I....-..E.
000000E0 75 22 82 E0 49 19 80 89 95 8D AB 91 8A D4 7D 21 u"..I.........}!
000000F0 C3 54 50 89 .TP.
2017-02-27 23:29:17.760 [INFO ] [.hap.impl.http.impl.AccessoryHandler] - Terminated homekit connection from /192.168.178.45:49194
hamwong
(Ham Wong)
March 25, 2017, 7:22am
7
I found a easy trick if homekit openhab devices stuck at updating/ no response until restart openhab, I found closed the app (by double tap home than swipe up) than turn off wifi for 2 seconds in iphone/ipad, mostly the case do it 1 time will be ok, the worst case is repeat above step 3 times, so far when I discover this trick, I don’t need restart openhab to bring back homekit in iphone, please share if this trick works or not works.
This does not work. The problem is not on the iOS device, it’s on the openhab side.
hamwong
(Ham Wong)
April 29, 2017, 10:49am
9
my founding is if you are not changing on *.items (especially relate to homekit), this tricks should works most of the time.
if you found your homekit always unavailable even from restart and you didn’t do any changes on openhab recently, I suggest you do a clean install on openhab,
only copied in files on /etc/openhab2/ (conf files) but all the stored settings by paper UI add it again manually.
it will turns openhab response real quick especially openhab runs on NAS or RPi.
semaf
(semaf)
December 30, 2017, 5:11pm
10
Did you find a way to clear the problem?
morchee
(Aydar)
January 21, 2018, 9:43am
11
We still doesnt have a way to fix ‘no answer’ problem?
nxn
(K K)
April 26, 2018, 7:00pm
12
I have the same issue, everything works for between 2 minutes and 12 hours and then just dies.
I’m losing hope here.
I’ve tried everything google could suggest. even reinstalled openhab 2 times and still i’m out of luck.
It worked fine for a couple of months until my server broke down and i had to reinstall the first time.
rkrisi
(Kristof Rado)
April 26, 2018, 7:35pm
13
I have the same problem…
However I have another problem, maybe someone has an answer for it:
I want to setup an old iPad (which can’t be updated to iOS 11) to use it as a wall mounted screen. However I can’t invite that iPad (I think it’s because it has iOS 10), when I try it says that this e-mail is not associated with an Apple ID.
Anyone had same issues? Solutions?
Gad_Ofir
(Gad Ofir)
April 26, 2018, 9:26pm
14
on windows also its working for a week witout any issue
only when i play around with the items i lose sync, and redo the steps for clear parings
I see the same type of error after every reboot of openhab2. In this situation, I have to clear all pairings on the console using
smarthome:homekit clearPairings
Then, I have to erase my home from my smart phone, reconnect to openhab and do all the initial setup of the homekit app all over. Slowly, but surely this is becoming a little painful…
smitopher
(Christopher Smith)
August 12, 2018, 2:50am
17
I want to add my experience
Everything runs fine for a few days to 2 weeks
Then Homekit just does not see OH and the items in Openhab.
Usually restarting OH will correct everything. One time I had to redo the OH/Homekit config.
What do I need to set up some Homekit logging in OH?
