Hi All,
I am trying to make Homekit works with Sensibo.
sensibo.items
Group gLivingRoomAC {homekit="HeaterCooler"}
Number:Temperature AC_Current_Temperature "Temperature [%.1f %unit%]" <temperature> (LivingRoom, gAC, gTemperature, has_state, gHistory, gLivingRoomAC) {channel="sensibo:sensibosky:home:salon:currentTemperature"}
Number:Dimensionless AC_Current_Humidity "Relative humidity [%.1f %%]" <humidity> (LivingRoom, gAC, gTemperature, has_state, gHistory, gLivingRoomAC) {channel="sensibo:sensibosky:home:salon:currentHumidity"}
Number:Temperature AC_Target_Temperature "Target temperature [%d %unit%]" <temperature> (LivingRoom, gAC, gTemperature, has_state, gHistory, gLivingRoomAC) {channel="sensibo:sensibosky:home:salon:targetTemperature", homekit="CurrentTemperature, HeatingThresholdTemperature, CoolingThresholdTemperature" [minValue=16, maxValue=30]}
String AC_Mode "AC mode [%s]" <acmod> (LivingRoom, gAC, has_state, gLivingRoomAC) {channel="sensibo:sensibosky:home:salon:mode", homekit="TargetHeaterCoolerState, CurrentHeaterCoolerState" [HEATING="heat", COOLING="cool"]}
String AC_Swing_Mode "AC swing mode [%s]" <acswing> (LivingRoom, gAC, has_state, gLivingRoomAC) {channel="sensibo:sensibosky:home:salon:swingMode"}
Switch AC_Office_Heater_MasterSwitch "AC power [%s]" <switch> (LivingRoom, gAC, has_state, gLivingRoomAC) {channel="sensibo:sensibosky:home:salon:masterSwitch", homekit="ActiveStatus"}
String AC_Office_Heater_Fan_Level "Fan level [%s]" <acfan> (LivingRoom, gAC, has_state, gLivingRoomAC) {channel="sensibo:sensibosky:home:salon:fanLevel"}
Number AC_Office_Heater_Timer "Timer seconds [%d]" <timer> {channel="sensibo:sensibosky:home:salon:timer"}
However each time I am changing the AC state its see its trying to make it with uppercase, not matter what i put there.
Even after restarting openhab, still see no changes.
2021-05-29 21:14:41.338 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'AC_Office_Heater_MasterSwitch' received command ON
2021-05-29 21:14:41.339 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'AC_Mode' received command COOL
2021-05-29 21:14:41.339 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'AC_Office_Heater_MasterSwitch' predicted to become ON
2021-05-29 21:14:41.340 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'AC_Mode' predicted to become COOL
2021-05-29 21:14:41.341 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'AC_Mode' changed from cool to COOL
2021-05-29 21:14:42.136 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'AC_Mode' changed from COOL to cool
2021-05-29 21:14:42.137 [INFO ] [o.internal.handler.SensiboSkyHandler] - Update command not sent; invalid state change for SensiboSky AC state: Cannot change mode to COOL, valid modes are {cool,fan,dry,heat}
