strange.
what is the name of the openhab group the metadata is attached to? BuitenNoordLumidora1?
can you show me the complete group?
what you see in the tab “code” ?
btw, you can assign the same item to multiple characterstics, e.g. ColorControl can be assigned to Hue and Saturation as well, it can handle it.
perfect. your group looks correct.
regarding metadata - it stores it at items, i.e. Color Control should have homekit tag with OnState.
you can also add homekit tag at item directly.
i.e.
please check whether Color Control has any homekit tag, if not, please add onState there manually via UI (as you did it for group)
unfortunately, the initial configuration is manual work.
usage of textual configuration would allow copy&paste, but still, you need to define all 40 groups.
do you really have multiple items representing one light? often a light can be represented by one Color Item, in such case, you dont need a group and can tag the Color Item as “lightning” and openHAB will automatically attach OnState, Hue, Brightness, Saturation to that item.
