HomeKit problems after migration from 2.5 to 3.3
Some days ago, I migrated my old 2.5 OH2 installation to the current stable 3.3 (based on OpenHabian).
I used a new Raspberry, installed the last image of Openhabian and restored my openhab backup into the new environment (both based on a Raspberry Pi 4b).
More or less everything is working (150 things, 557 items based on 10 bindings).
In addition I used the HomKit integration for
  • heater
  • switches
  • garage door
  • temperature sensor
  • window blinds
Unfortunately, after switching to 3.3, I only see my heaters.
No switches, no window blinds, no garage door, no temp sensors :frowning:
I tried to uninstall and install HomeKit integration → no change
I tried to remove the OpenHAB bridge on my phone → no change
What can I do?
there was a major change in the homekit configuration at item level.
in 2.5 you could use labels, something like
Switch light "Light" ["Lighting"]
this is not supported in 3.x anymore. you have to use metadata
Switch light "Light" {homekit="Lighting"}
so, please make sure all your items have metadata attached to them
Thanks a lot !
