Hi, is someone succeeded in creating a qrcode for pairing openHAB bridge with iOS devices?
I’m trying with the apple provided soft “HomeKit Accessory Simulator” which is additional part of XCode, but it doesn’t work.
Is someone found another way?
Regards
i would love to have QRCodes as well, but it is not supported by the library we use for homekit binding.
For QRCode we need to send additional information (setupID) but we cannot do it right now.
Definitely a good feature request.
until then you need to enter the PIN code manually.
Ok, thank you for your answer.
You mean the it is not possible to specify setupID as a custom value in expert mode HomeKit service configuration?
correct, it is not possible to specify homekit setupID in openHAB.
