this log means that an update about item state change was sent to iOS device or to iOS bridge, e.g. apple tv.
in your case it was published to device with IP 192.168.2.227 / 192.168.2.131
i would try to disconnect all iOS device and keep only one connected to homekit.
What was the solution? I have the same issue using OH3 (using config files). Need to restart homekit bundle via karaf regularly to get homekit working again. Everything else works fine.
FYI: I have 37 HomeKit items and 2 connected iPhones.
Thanks for you reply. I was already on OH 3.2 running as docker image.
Nevertheless I pulled the latest image as of today. Don’t know whether there is any difference to the version a few days ago. I will follow up here if the problem re-occurs.
