Homekit/Siri openHAB 2 integration
(Christian) #1
Hi there,
i have just installed openHABian 1.4.1 and upgraded openHAB to 2.4.0 snapshot.
Also i installed the Homekit Integration through Paper UI and configured it. The openHAB Bridge is connected to the Homekit on my Home App, but no items are shown yet. I also tried to add the Homebridge-openhab2 Plugin in the Raspberry Homebridge, but this one is also not working.
What i am doing wrong?
Thanks a lot.
Regards
Christian
(Psyciknz) #2
i don’ t know how you do it in paperui, but to expose items (like a light switch) to homekit I had to add [“lighting”] to my items file. I don’t know what the equivalent is in paperui.
(Christian) #3
thank you very much. I uninstalled the openHab2 Bridge on my Raspberry again and just installed the openHAB2 Homekit Support. After i set up the Homekit Tags via REST API everything works fine for me.
Best regards
Christian
(Dan) #4
I’ve given up on the official homekit integration, and hacked a quick bridge between openhab and homekit using HAP-NodeJS. For my use case - wanting to trigger scenes like “good morning” - it works perfectly and without too much trouble - or indeed more than elementary knowledge of nodejs.
Let me know if anyone else is interested and I’ll post a short tutorial.
(Christian) #5
Hello Dan,
i am very insterested in your turotial about HAP-NodeJS.
Please post it here.
Thank you very much
Regards
Christian
(Dan) #6
Sure. My brilliant solution just stopped working. Let me keep an eye on it, and I’ll report back when I’ve found/fixed whatever the problem is.
(Dan) #7
I’ve posted my hacked-together solution: More reliable Homekit alternative using a simple nodejs bridge
