@beowulfe, @maihacke
Hi, did you plan to compile a jar homekit addon with the latest improvement included in 2.3 release? Especially the ability of make the bridge name configurable?
I’m using your binding for few month without any problem!!
Regards.
I notice that I’ve installed 2.3 OH release and the lastest mailhacke still working perfectly.
For me it’s working.
I upgraded to 2.3
uninstalled “homekit intergration 2.3.0” with paperUI
Installed latest version of homekit int this thread thru console.
Regards
I have not upgraded to the version that supports the blinds as last time i had problems repairing and it took me days to revert.
I am now on 2.3 with the default homekit version and i implemented my blinds as a dimmer. It allows me to ask Siri to open the blinds 0%, X% or 100% which works fine as a workaround. The only issue is that turning of all lights also impacts the blinds.
My question to people that have blinds working, can you ask Siri not only to open and close but also open them x%.?
Two points that are key for succesfuly deploy this binding for me
Install HomeKit via UI (to install dependencies)
Stop HomeKit via Karaf
Copy the new binding in addons folder
Wait a minute to be installed
Start the new binding
Clear Painrings
Add new device on apple device
Cleared the pairing as described above, setting and coupling the new binding - it worked … including the blinds. I was happy - for an half hour. Then homekit lost the connection (red tag “no response” “Keine Antwort”). I was not able to bring it back to work. So - no homekit anymore. This binding is unstable and users waste to much time with it.
I can’t figure out the cause of the problem:
network settings
iCloud settings
different combination of iOS versions and iOS devices
changes of Apple within the HomeKit System
A reliable working homekit Binding would be phantastic!
Try restarting openHAB. I had a similar experience after I connected it first to HomeKit. Now it is running stable for days and connects fine even if I am away from home.
cleared pairing in OH and in the HomeKit App on the iOS device. Restarted OH.
The i used another device (not the same then before!), here my iPad. The it worked.
Also, it seemed to help: saving the .item file again. This seemed to refresh the HomeKit items and to trigger the HomeKit Binding for a new “scan” and “publish” of the items to the app. But i’m not sure.
Im quite new here. Can anyone please explain me how to install the custom version for rollershutter and homekit support. Im wuite a noob That would be really nice. Thank you very much!
I would also be interested in a little warm-up, how this works. Should I delete the built-in HomeKit support? What does these forks has besides beowulfe’s version? Rollershutter, different lamps, what??
I can see the blinds icon in “Home” on my phone , switch & dimmer & temp. work well but Only “Blind” no work … ( Can see the Blinds Reading same as paperUI ) I’m using the the KNXshutter & work well in basicUI & paperUI …
Was just glancing through changes of 2.4 Milestone 5 build and it looks like OH is getting some of the ESH ontology / semantics that I believe have been causing some issues for HomeKit in OH2.
Does this mean that it will be easier for new item types on HomeKit add-on?
i´m working with your version postet above. i´ve tried several things to get my rollershutters to work. my items-file contains 72 items. serverals lights, switches and rollershutters. the most is knx.
When i try to get homekit to work with all items, i will get a “no response” notification on every item and no item will work.
but when i delete the blinds from the items-file, the homekit-app shows every item left in the file without any issues. Everthings works fine.
I think the main problem of this is the use of the [“Blinds”] - Tags.
Is there anything what i missed in my setup?
My openhab version is 2.3.0 - homekit with iOS12.1.1
