Hi Guys,
finally i managed to get Homekit working again.
But somehow i dont get the syntax right. only a few items work, but most aren’t.
a simple OSRAM Plug ( doesn’t work , doesn’t even see it in Home.app )
Switch Hue_Plug_1_Toggle "Garten" <garden> (PhilipsHUE,PhilipsHUELight,gLight) { homekit="Switchable", channel="hue:0010:0017886eb013:7:switch" }
Sonoff Power ON/OFF not working , can see it in Home.app
( Humidity & Temp. work )
// Sonoff TH 16 - Temperature / Humidity
Switch Sonoff_TH16_Power "Sonoff TH16 Power [MAP(de.map):%s]" <poweroutlet> (gSonoff_2019) {homekit="Switchable", channel="mqtt:topic:sonoff_th16:power"}
String Sonoff_TH16_String "Sonoff TH16 String" <poweroutlet> (gSonoff_2019) {channel="mqtt:topic:sonoff_th16:state"}
Number Sonoff_TH16_Temp "Sonoff TH16 Temp [%s °C]" <temperature> (gSonoff_2019) {homekit="TemperatureSensor", channel="mqtt:topic:sonoff_th16:temperature"}
Number Sonoff_TH16_Humidity "Sonoff TH16 Humidity [%s %%]" <humidity> (gSonoff_2019) {homekit="HumiditySensor", channel="mqtt:topic:sonoff_th16:humidity"}
Number Sonoff_TH16_RSSI "Sonoff TH16 WLAN Stärke [%.0f %%]" <wifi> (gSonoff_2019) {channel="mqtt:topic:sonoff_th16:rssi"}
Number Sonoff_TH16_Load "Sonoff TH16 Load Avg. [%s %%]" <heating> (gSonoff_2019) {channel="mqtt:topic:sonoff_th16:load"}
String Sonoff_TH16_Uptime "Sonoff TH16 Uptime" <time> (gSonoff_2019) {channel="mqtt:topic:sonoff_th16:uptime"}
String Sonoff_TH16_ssid "Sonoff TH16 WiFi" <wifi> (gSonoff_2019) {channel="mqtt:topic:sonoff_th16:ssid"}
LED Strip Color-Change not working , can see it in Home.app and can turn On/OFF
Switch LED_2_power "LED Schreibtisch" <led_strip> (gLight,OG_Office_Light) {homekit="Lighting, Lighting.Hue, Lighting.Brightness, Lighting.Saturation", channel="wifiled:wifiled:F0FE6B678010:power"}
Color LED_2_color "LED 2 Farbe" <hue> (OG_Office) {homekit="Lighting, Lighting.Hue, Lighting.Brightness, Lighting.Saturation", channel="wifiled:wifiled:F0FE6B678010:color"}
and whats the best way to refresh the “homekit stuff”
Console -> openhab:homekit list
gives me still items, where i already deleted the homekit syntax out of it.
any advice would be much appreciated - thanks!
