Good day to all of you,
I installed and configured the Homematic binding, but obviously I made a mistake. I am running Homematic’s OCCU on the same server. The binding says “online” in PaperUI, but it doesn’t show things in the inbox.
My configuration in /srv/openhab2-userdata/jsondb/org.eclipse.smarthome.core.thing.Thing.json is
"homematic:bridge:1b73a124": {
"class": "org.eclipse.smarthome.core.thing.internal.BridgeImpl",
"value": {
"label": "HomematicCentral",
"channels": [],
"configuration": {
"properties": {
"cuxdPort": 8701,
"socketMaxAlive": 900,
"reconnectInterval": 0,
"aliveInterval": 900,
"timeout": 15,
"hmIpPort": 2010,
"wiredPort": 2000,
"gatewayType": "ccu",
"callbackHost": "192.168.1.200",
"groupPort": 9292,
"gatewayAddress": "0.0.0.0",
"rfPort": 2001
I tried different values for the gateway-address (i.e. 192.168.1.200, 127.0.0.1), the current one I’ve retrieved via open ports on the pi
But when I go to the inbox in paperUI and choose to search things, it searches without any result. I also added the things manually, and eventually they show up under configuration, but with state offline. I have linked my devices via homematic manager and could manage them their. Somehow the communication between openHAB and Homematic OCCU seems not to work.
Your help is very appreciated!
Thanks in advance.
