Homematic ASIR Problem: Duration QuantityType
Hi There,
since the newest offical release of openhab (2.4) I have problems setting the homematic alarm siren duration value:
Number:Dimensionless HmIPAlarmsirene_3DURATIONVALUE “Duration Value [%.0f]” {channel=“homematic:HmIP-ASIR:3014F711A0001F98A99A3C9D:000AD8A990C7F6:3#DURATION_VALUE”}
with command:
HmIPAlarmsirene_3OPTICALALARMSELECTION.sendCommand(“DOUBLE_FLASHING_REPEATING”)
HmIPAlarmsirene_3ACOUSTICALARMSELECTION.sendCommand(“DISABLE_ACOUSTIC_SIGNAL”)
HmIPAlarmsirene_3DURATIONUNIT.sendCommand(“M”)
HmIPAlarmsirene_3DURATIONVALUE.sendCommand(3)
I get the following warning and no effect on the siren (before the update it worked):
16:29:24.454 [WARN ] [mematic.handler.HomematicThingHandler] - Can’t convert type QuantityType with value ‘3’ to INTEGER value with DecimalTypeConverter for ‘000AD8A990C7F6:3#DURATION_VALUE’, please check the item type and the commands in your scripts
Please, can anyone help?
Is there a fix available and if how to obtain?
Erik
Yes…
