2016-01-16 10:26:15.368 [INFO ] [ematic.internal.bus.HomematicBinding] - HomematicConfig[host=192.168.100.40,timeout=15,callbackHost=192.168.100.120,callbackPort=9123,aliveInterval=300,reconnectInterval=disabled]
2016-01-16 10:26:15.371 [INFO ] [l.communicator.HomematicCommunicator] - Starting Homematic communicator
2016-01-16 10:26:15.425 [INFO ] [l.communicator.HomematicCommunicator] - Homematic ServerId[name=CCU,version=2.15.5,address=KEQXXXXXXX]
2016-01-16 10:26:15.447 [INFO ] [ternal.communicator.client.CcuClient] - Starting CcuClient
2016-01-16 10:26:15.574 [INFO ] [ic.internal.communicator.StateHolder] - Loading Homematic datapoints
2016-01-16 10:26:17.187 [ERROR] [l.communicator.HomematicCommunicator] - Could not start Homematic communicator: 2 counts of IllegalAnnotationExceptions
org.openhab.binding.homematic.internal.communicator.client.HomematicClientException: 2 counts of IllegalAnnotationExceptions
at org.openhab.binding.homematic.internal.communicator.client.CcuClient.sendScript(CcuClient.java:322)[166:org.openhab.binding.homematic:1.9.0.201601150214]
at org.openhab.binding.homematic.internal.communicator.client.CcuClient.sendScriptByName(CcuClient.java:254)[166:org.openhab.binding.homematic:1.9.0.201601150214]
at org.openhab.binding.homematic.internal.communicator.client.CcuClient.iterateAllDatapoints(CcuClient.java:126)[166:org.openhab.binding.homematic:1.9.0.201601150214]
at org.openhab.binding.homematic.internal.communicator.StateHolder.loadDatapoints(StateHolder.java:84)[166:org.openhab.binding.homematic:1.9.0.201601150214]
at org.openhab.binding.homematic.internal.communicator.HomematicCommunicator.start(HomematicCommunicator.java:93)[166:org.openhab.binding.homematic:1.9.0.201601150214]
at org.openhab.binding.homematic.internal.bus.HomematicBinding.updated(HomematicBinding.java:95)[166:org.openhab.binding.homematic:1.9.0.201601150214]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.ConfigurationManager$UpdateConfiguration.run(ConfigurationManager.java:1753)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:143)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:110)[7:org.apache.felix.configadmin:1.8.8]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_06]
Caused by: com.sun.xml.internal.bind.v2.runtime.IllegalAnnotationsException: 2 counts of IllegalAnnotationExceptions
@XmlAttribute/@XmlValue muss einen Java-Typ referenzieren, der Text in XML zugeordnet ist.
this problem is related to the following location:
at protected java.lang.Number org.openhab.binding.homematic.internal.model.HmValueItem.minValue
at org.openhab.binding.homematic.internal.model.HmValueItem
at org.openhab.binding.homematic.internal.model.HmDatapoint
at private java.util.List org.openhab.binding.homematic.internal.model.HmChannel.datapoints
at org.openhab.binding.homematic.internal.model.HmChannel
at private java.util.List org.openhab.binding.homematic.internal.model.HmDevice.channels
at org.openhab.binding.homematic.internal.model.HmDevice
at private java.util.List org.openhab.binding.homematic.internal.model.HmDeviceList.devices
at org.openhab.binding.homematic.internal.model.HmDeviceList
at protected java.lang.Number org.openhab.binding.homematic.internal.model.HmValueItem.maxValue
at com.sun.xml.internal.bind.v2.runtime.IllegalAnnotationsException$Builder.check(IllegalAnnotationsException.java:91)[:1.8.0_06]
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl.getTypeInfoSet(JAXBContextImpl.java:445)[:1.8.0_06]
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl.<init>(JAXBContextImpl.java:277)[:1.8.0_06]
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl.<init>(JAXBContextImpl.java:124)[:1.8.0_06]
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl$JAXBContextBuilder.build(JAXBContextImpl.java:1123)[:1.8.0_06]
at com.sun.xml.internal.bind.v2.ContextFactory.createContext(ContextFactory.java:147)[:1.8.0_06]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_06]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_06]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_06]
at java.lang.reflect.Method.invoke(Method.java:483)[:1.8.0_06]
at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:247)[:1.8.0_06]
at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:234)[:1.8.0_06]
at javax.xml.bind.ContextFinder.find(ContextFinder.java:462)[:1.8.0_06]
at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:641)[:1.8.0_06]
at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:584)[:1.8.0_06]
at org.openhab.binding.homematic.internal.communicator.client.CcuClient.sendScript(CcuClient.java:318)[166:org.openhab.binding.homematic:1.9.0.201601150214]
… 12 more
2016-01-16 10:26:17.207 [INFO ] [l.communicator.HomematicCommunicator] - Shutting down Homematic communicator
2016-01-16 10:26:17.219 [INFO ] [nal.communicator.client.BinRpcClient] - Interface BidCos-Wired not available, disabling support.
2016-01-16 10:26:17.226 [INFO ] [nal.communicator.client.BinRpcClient] - Interface CUxD not available, disabling support.
