after a crash I try to re-setup my openhabian from scratch to do it better this time ;-). Now, when trying to connect to the CCU2, I cannot connect. So these are the loggings:
The IP-Adress is the right one, and before it was working already several months very stable (with my old openhab2-installation). Any ideas what I could try?
I am still struggeling here. Any idea what to try?
When I look on the logging of the homematic, no entries seems to match the openhab-message. As if it wouldn’t even get there.
I already uninstalled and reinstallend the homematic Binding several times - didn’t change anything. I would even go and either reset the raspberry (oepnhab2-server) or the ccu2 and start again from scratch, if I could only figure out who has the problem - the raspberry or the CCU2?
Thanks SO MUCH for your reply! The last hours I continued trying and upgraded openhab to the 2.2 and the homematic binding as well - and it worked!! Had all my devices in the inbox. But somehow this upgrade crashed the logging mechanism of openhab, so I don’t get any more output to my logfiles. I tried downgrading again - still seems to work, at least I still see my items in the inbox, but again no more logging. So currently I am struggeling on this issue.
Regarding your questions:
there were no more Homematic entries in the logging after “Stopping Homematic”
Debian Version 8.0
CCU firewall settings allow full access
The other thread you mentioned seems very related- actually I think I saw similar log files every time I wanted to connect to the CCU for a second time
(I installed the binding, tried to connect to the CCU - it didn’t work and I saw the logging I posted - I removed the CCU - tried to connect again - didn’t work again, and I saw a logging different from the first time and similar to the one in the thread you linked) - so I uninstalled the binding, reinstalled it and tried again.
Unfortunately those log files are gone now - I just deleted them in order to help openhab lo start logging again.
Will keep you posted on further findings as soon as I figure out to start logging again.
