Thank you so much for the fast testversion.
I have allready installed it.
But because of my last post (restart of CCU + openhab) actually everythinks seems good (with DRI32):
2022-01-20 12:11:05.821 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG = true, vdp null, long active false, uses start false
2022-01-20 12:11:05.824 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling LONG as start
2022-01-20 12:11:05.825 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG, value true, button state null -> LONG_PRESSED
2022-01-20 12:11:05.847 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG_START = true, vdp LONG_PRESSED, long active true, uses start false
2022-01-20 12:11:05.849 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG_START, value true, button state LONG_PRESSED -> LONG_PRESSED
2022-01-20 12:11:06.062 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG = true, vdp LONG_PRESSED, long active true, uses start true
2022-01-20 12:11:06.064 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling LONG as repetition
2022-01-20 12:11:06.066 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG, value true, button state LONG_PRESSED -> LONG_REPEATED
2022-01-20 12:11:06.301 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG = true, vdp LONG_REPEATED, long active true, uses start true
2022-01-20 12:11:06.303 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling LONG as repetition
2022-01-20 12:11:06.304 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG, value true, button state LONG_REPEATED -> LONG_REPEATED
2022-01-20 12:11:06.575 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG = true, vdp LONG_REPEATED, long active true, uses start true
2022-01-20 12:11:06.577 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling LONG as repetition
2022-01-20 12:11:06.579 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG, value true, button state LONG_REPEATED -> LONG_REPEATED
2022-01-20 12:11:06.817 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG = true, vdp LONG_REPEATED, long active true, uses start true
2022-01-20 12:11:06.819 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling LONG as repetition
2022-01-20 12:11:06.821 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG, value true, button state LONG_REPEATED -> LONG_REPEATED
2022-01-20 12:11:07.065 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG = true, vdp LONG_REPEATED, long active true, uses start true
2022-01-20 12:11:07.067 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling LONG as repetition
2022-01-20 12:11:07.068 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG, value true, button state LONG_REPEATED -> LONG_REPEATED
2022-01-20 12:11:07.305 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG = true, vdp LONG_REPEATED, long active true, uses start true
2022-01-20 12:11:07.306 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling LONG as repetition
2022-01-20 12:11:07.308 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG, value true, button state LONG_REPEATED -> LONG_REPEATED
2022-01-20 12:11:07.563 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG = true, vdp LONG_REPEATED, long active true, uses start true
2022-01-20 12:11:07.565 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling LONG as repetition
2022-01-20 12:11:07.567 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG, value true, button state LONG_REPEATED -> LONG_REPEATED
2022-01-20 12:11:07.815 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG = true, vdp LONG_REPEATED, long active true, uses start true
2022-01-20 12:11:07.817 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling LONG as repetition
2022-01-20 12:11:07.819 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG, value true, button state LONG_REPEATED -> LONG_REPEATED
2022-01-20 12:11:07.853 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG_START = false, vdp LONG_REPEATED, long active true, uses start true
2022-01-20 12:11:07.855 [INFO ] [irtual.ButtonVirtualDatapointHandler] - start timeout while repetition
2022-01-20 12:11:07.856 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG_START, value false, button state LONG_REPEATED -> LONG_REPEATED
2022-01-20 12:11:08.062 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG = true, vdp LONG_REPEATED, long active true, uses start true
2022-01-20 12:11:08.066 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling LONG as repetition
2022-01-20 12:11:08.070 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG, value true, button state LONG_REPEATED -> LONG_REPEATED
2022-01-20 12:11:08.295 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG = true, vdp LONG_REPEATED, long active true, uses start true
2022-01-20 12:11:08.299 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling LONG as repetition
2022-01-20 12:11:08.301 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG, value true, button state LONG_REPEATED -> LONG_REPEATED
2022-01-20 12:11:08.816 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG_RELEASE = true, vdp LONG_REPEATED, long active true, uses start true
2022-01-20 12:11:08.820 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG_RELEASE, value true, button state LONG_REPEATED -> LONG_RELEASED
2022-01-20 12:11:10.314 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG = false, vdp LONG_RELEASED, long active false, uses start true
2022-01-20 12:11:10.316 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG, value false, button state LONG_RELEASED -> null
2022-01-20 12:11:10.825 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handling virtual button event on 00171BE99324D8:1: dp PRESS_LONG_RELEASE = false, vdp null, long active false, uses start true
2022-01-20 12:11:10.827 [INFO ] [irtual.ButtonVirtualDatapointHandler] - Handled virtual button event on 00171BE99324D8:1: press type LONG_RELEASE, value false, button state null -> null
