I haven’t found anything regarding this issue, maybe one of you have a clue how to fix it:
I use the Homematic HmIP-DLD (Lock | Homematic IP (homematic-ip.com)) and since the firmware update to the current version “1.4.10”, I receive the following warning message in my logs:
Channel not found for datapoint '002XXXXXXXXXXXX:0#ERROR_JAMMED'
I haven’t found a corresponding openHAB device channel which could solve this error. I don’t know if this correlates with this issue but in the firmware changelogs you can see the following entry:
Version V1.4.0 - 2021-06-09
** Bugfix
* ACCEPT_ALL_TRIPLE_BURST_LISTENING_DEVICES not working
** New Feature
* new parameter: disable acoustic channel state
* WP_OPTIONS link parameter
** Improvement
* Disengage at VeryLowBat
* add parameter door lock end stop offset
* Improve low-bat detection
* Transmit "jammed" as error
Maybe the Homematic openHAB binding needs to be adapted? I receive this error message even if the device isn’t active, nor in an error state.
I appreciate your help!
