I had to change my old Hm water detector to an HmIP one. I’m using Homematic Raspi and OH3.
The SWD could be integrated as usual and channel 0 (Battery and Signal) delivers data as usual.
But channel 1 (ALARMSTATE, WATERLEVEL_DETECTED and MOISTURE_DETECTED) remains quiet (NULL).
As channel 0 is working, I guess it is more a config question. Any hints?
Over the weekend, I’ve found time to evaluate and solve the connection. So more for documentation for future issues.
On the old Homematic water sensor you had one item with 3 different states. The state was either OFF, WATERLEVEL_DETECTED, MOISTURE_DETECTED.
This changed now to 3 different ON/OFF-Channels which have to be attached to 3 items.
rule "itemHomeMaticWater1 MOISTURE_DETECTED"
Item itemHomeMaticWater1_m changed to ON
sendNotification("abc", "HomeMatic Wassersensor meldet FEUCHTE.")
rule "itemHomeMaticWater_UG1 WATER DETECTED"
Item itemHomeMaticWater1_w changed to ON
sendNotification("abc", "HomeMatic Wassersensor meldet WASSER.")
