I’ve installed a Homematic-Bridge successfully and everything worked fine. I could create things and items from Homematic devices and could control them as well from Openhab 2.4
Now I’ve installed openHab cloud in order to control my smart home from abroad. When I’ve opened Papier UI the first time from myOpenhab, I could see no Homematic items anymore - the bridge and the items went offline. The bridge says that jetty start failed.
Openhab.log looks like that:
2019-02-17 19:06:17.983 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-02-17 19:06:18.064 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2019-02-17 19:06:18.347 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '53.5781376,9.957376'.
2019-02-17 19:06:33.041 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'W88LabFullStack.rules'
2019-02-17 19:06:33.331 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-02-17 19:06:33.962 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'W88Lab.sitemap'
2019-02-17 19:06:36.411 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://169.254.186.27:8080
2019-02-17 19:06:36.415 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://169.254.186.27:8443
2019-02-17 19:06:36.931 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-02-17 19:06:37.361 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.11.208' with clientid paho46711633887 and file store '/var/lib/openhab2/mqtt/192.168.11.208'
2019-02-17 19:06:51.809 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = e4d9cdc6-f2b9-48c7-aff4-ed6f6d11a2aa, base URL = http://localhost:8080)
2019-02-17 19:06:58.154 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway '3014F711A0001F98A9A57FA6' not available, disabling support
2019-02-17 19:06:58.306 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=3.41.11,address=PEQ1841062,rf=true,wired=false,hmip=true,cuxd=true,group=true]
2019-02-17 19:07:13.705 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway '3014F711A0001F98A9A57FA6' not available, disabling support
2019-02-17 19:07:13.793 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=3.41.11,address=PEQ1841062,rf=true,wired=false,hmip=true,cuxd=true,group=true]
2019-02-17 19:07:29.024 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway '3014F711A0001F98A9A57FA6' not available, disabling support
2019-02-17 19:07:29.123 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=3.41.11,address=PEQ1841062,rf=true,wired=false,hmip=true,cuxd=true,group=true]
2019-02-17 19:07:47.214 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway '3014F711A0001F98A9A57FA6' not available, disabling support
2019-02-17 19:07:47.273 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=3.41.11,address=PEQ1841062,rf=true,wired=false,hmip=true,cuxd=true,group=true]
2019-02-17 19:08:02.478 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway '3014F711A0001F98A9A57FA6' not available, disabling support
2019-02-17 19:08:02.539 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=3.41.11,address=PEQ1841062,rf=true,wired=false,hmip=true,cuxd=true,group=true]
2019-02-17 19:08:17.739 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway '3014F711A0001F98A9A57FA6' not available, disabling support
2019-02-17 19:08:17.805 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=3.41.11,address=PEQ1841062,rf=true,wired=false,hmip=true,cuxd=true,group=true]
2019-02-17 19:08:33.005 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway '3014F711A0001F98A9A57FA6' not available, disabling support
Has anybody an idea what’s going wrong here?
