Homematic CCU still initializing - again
Hello professionals,
I have openHAB2 running on an Windows Server 2008r2 and a CCU2, which I want to bind.
  • Openhab is working an can be adressed via openhab.org
  • CCu2 is working. It has been connected to an actor, that works, when I activate it.
  • From the the server (192.168.178.20) it is possible to open the CCU2 page (192.168.178.53) by Firefox
  • Both IP-adresses are fixed, both are connected by LAN via Fritzbox Cable
  • The firewall in CCu2 is open
  • I restarted both
  • I removed ccu2 and added it several times
… but it says initalising for a long time and then offline.
What shall I do?
obenhab says the following (part of long log)
2018-02-26 20:07:32.036 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 3e97ac7d-48a4-44d9-8bbd-37fb9d7852f0, base URL = http://localhost:8080)
2018-02-26 20:07:37.020 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-02-26 20:07:38.395 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-02-26 20:07:38.426 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-02-26 20:07:38.458 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-02-26 20:07:40.254 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:07:41.301 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:07:41.458 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:09:49.317 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:09:50.379 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:09:50.426 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:11:56.512 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:11:57.559 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:11:57.622 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:14:05.622 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:14:06.669 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:14:06.778 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:16:14.684 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:16:15.794 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:16:15.825 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:18:23.528 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:18:24.606 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:18:24.731 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:20:32.497 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:20:33.559 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:20:33.591 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:21:33.981 [INFO ] [st.core.internal.thing.ThingResource] - Received HTTP DELETE request for update at ‘things/homematic:bridge:ccu2’ for the unknown thing ‘homematic:bridge:ccu2’.
2018-02-26 20:21:41.739 [INFO ] [st.core.internal.thing.ThingResource] - Received HTTP DELETE request for update at ‘things/homematic:bridge:ccu2’ for the unknown thing ‘homematic:bridge:ccu2’.
2018-02-26 20:24:02.348 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:24:03.442 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:24:03.489 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:26:11.188 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:26:12.266 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:26:12.298 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:28:20.079 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:28:21.141 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:28:21.188 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:30:28.954 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:30:30.016 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:30:30.063 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:32:37.985 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:32:39.048 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:32:39.095 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:34:47.110 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:34:48.173 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘ccu2’ not available, disabling support
2018-02-26 20:34:48.220 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:36:56.235 [INFO ] [ternal.communicator.client.RpcClient] - In
events.log says
2018-02-26 20:21:22.180 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from REMOVED to UNINITIALIZED
2018-02-26 20:21:22.192 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from REMOVED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-02-26 20:24:01.227 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from UNINITIALIZED to INITIALIZING
2018-02-26 20:24:18.563 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from INITIALIZING to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:25:13.766 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:26:27.360 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:27:22.485 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:28:36.298 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:29:31.470 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:30:45.095 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:31:40.251 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:32:54.126 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:33:49.298 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:35:03.251 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:35:58.423 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:37:12.345 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:38:07.501 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:39:21.610 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): java.net.ConnectException: Connection refused: no further information
2018-02-26 20:40:13.501 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): java.net.ConnectException: Connection refused: no further information to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:41:08.579 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:42:31.391 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:43:26.532 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:44:49.423 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:45:44.751 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:46:58.329 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:47:53.579 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:49:06.970 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:50:02.251 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:51:15.735 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:52:10.985 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:53:24.532 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:54:19.798 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:55:33.345 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:56:28.595 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:57:42.423 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:58:37.657 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:59:51.095 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:00:46.345 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:01:59.891 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:02:55.141 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:04:08.688 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:05:04.001 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:06:17.516 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:07:12.829 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:08:26.204 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:09:21.454 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:10:35.110 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:11:30.345 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:12:44.110 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:13:39.345 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:14:52.985 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:15:48.266 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:17:01.766 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:17:57.001 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:19:10.548 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:20:05.766 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:21:19.376 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:22:14.641 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:23:28.235 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:24:23.470 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:25:37.423 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:26:32.626 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:27:46.485 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:28:41.704 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:29:55.407 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:30:50.610 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:32:04.204 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:32:59.423 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:34:12.876 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:35:08.110 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:36:21.782 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:37:16.970 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:38:30.563 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:39:25.798 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:40:39.423 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:41:34.626 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:42:48.063 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:43:43.391 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:44:56.985 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:45:52.251 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:47:05.766 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:48:00.985 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:49:14.688 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:50:09.907 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:51:23.782 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:52:19.001 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:53:19.148 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from OFFLINE (COMMUNICATION_ERROR) to REMOVING
2018-02-26 21:53:19.160 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from REMOVING to REMOVED
2018-02-26 21:53:19.168 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from REMOVED to UNINITIALIZED
2018-02-26 21:53:24.215 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from REMOVED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-02-26 21:55:37.781 [hingStatusInfoChangedEvent] - ‘homematic:bridge:ccu2’ changed from UNINITIALIZED to INITIALIZING
Some more information:
The CCU2 has a new firmware (2.31.25) and openhab is 2.2.0 - so upgrading should not be the solution.
Thank you for your help!
Philipp
First of all, please use the formatting options of the forum software with your log file.
Hi Joachim,
sorry. Which formatting option should I use?
Philipp
I’m not sure, i’m on my phone. I think just code fences or items code fences. These long logs need scrollbars and are similar to csv, which is used for items.
Select the code fence first, then copy your log inside, otherwise it’s getting ugly. :wink:
06.496 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from UNINITIALIZED to INITIALIZING
2018-02-26 19:35:27.082 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from INITIALIZING to REMOVING
2018-02-26 19:35:27.098 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from REMOVING to REMOVED
2018-02-26 19:35:27.102 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from REMOVED to UNINITIALIZED
2018-02-26 19:35:27.223 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from REMOVED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-02-26 19:37:59.254 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from UNINITIALIZED to INITIALIZING
2018-02-26 20:07:38.879 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from UNINITIALIZED to INITIALIZING
2018-02-26 20:07:56.536 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from INITIALIZING to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:08:51.708 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:10:05.473 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:11:00.614 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:12:12.669 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:13:07.848 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:14:21.794 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:15:16.981 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:16:30.856 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:17:26.028 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:18:39.778 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:19:34.950 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:20:48.622 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:21:22.153 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to REMOVING
2018-02-26 20:21:22.157 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from REMOVING to REMOVED
2018-02-26 20:21:22.180 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from REMOVED to UNINITIALIZED
2018-02-26 20:21:22.192 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from REMOVED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-02-26 20:24:01.227 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from UNINITIALIZED to INITIALIZING
2018-02-26 20:24:18.563 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from INITIALIZING to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:25:13.766 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:26:27.360 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:27:22.485 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:28:36.298 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:29:31.470 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:30:45.095 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:31:40.251 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:32:54.126 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:33:49.298 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:35:03.251 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:35:58.423 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:37:12.345 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:38:07.501 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:39:21.610 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): java.net.ConnectException: Connection refused: no further information
2018-02-26 20:40:13.501 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): java.net.ConnectException: Connection refused: no further information to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:41:08.579 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:42:31.391 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:43:26.532 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:44:49.423 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:45:44.751 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:46:58.329 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:47:53.579 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:49:06.970 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:50:02.251 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:51:15.735 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:52:10.985 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:53:24.532 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:54:19.798 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:55:33.345 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:56:28.595 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:57:42.423 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 20:58:37.657 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 20:59:51.095 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:00:46.345 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:01:59.891 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:02:55.141 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:04:08.688 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:05:04.001 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:06:17.516 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:07:12.829 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:08:26.204 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:09:21.454 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:10:35.110 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:11:30.345 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:12:44.110 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:13:39.345 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:14:52.985 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:15:48.266 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:17:01.766 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:17:57.001 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:19:10.548 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:20:05.766 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:21:19.376 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:22:14.641 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:23:28.235 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:24:23.470 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:25:37.423 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:26:32.626 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:27:46.485 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:28:41.704 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:29:55.407 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:30:50.610 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:32:04.204 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:32:59.423 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:34:12.876 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:35:08.110 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:36:21.782 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:37:16.970 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:38:30.563 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:39:25.798 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:40:39.423 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:41:34.626 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:42:48.063 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:43:43.391 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:44:56.985 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:45:52.251 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:47:05.766 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:48:00.985 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:49:14.688 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:50:09.907 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:51:23.782 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (COMMUNICATION_ERROR): Read timed out
2018-02-26 21:52:19.001 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to OFFLINE (COMMUNICATION_ERROR)
2018-02-26 21:53:19.148 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from OFFLINE (COMMUNICATION_ERROR) to REMOVING
2018-02-26 21:53:19.160 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from REMOVING to REMOVED
2018-02-26 21:53:19.168 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from REMOVED to UNINITIALIZED
2018-02-26 21:53:24.215 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from REMOVED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-02-26 21:55:37.781 [hingStatusInfoChangedEvent] - 'homematic:bridge:ccu2' changed from UNINITIALIZED to INITIALIZING
and openhab.log:
2018-02-26 20:07:40.254 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:07:41.301 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:09:49.317 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:09:50.379 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:11:56.512 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:11:57.559 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:14:05.622 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:14:06.669 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:16:14.684 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:16:15.794 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:18:23.528 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:18:24.606 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:20:32.497 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:20:33.559 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:21:33.981 [INFO ] [st.core.internal.thing.ThingResource] - Received HTTP DELETE request for update at 'things/homematic:bridge:ccu2' for the unknown thing 'homematic:bridge:ccu2'.
2018-02-26 20:21:41.739 [INFO ] [st.core.internal.thing.ThingResource] - Received HTTP DELETE request for update at 'things/homematic:bridge:ccu2' for the unknown thing 'homematic:bridge:ccu2'.
2018-02-26 20:24:02.348 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:24:03.442 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:26:11.188 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:26:12.266 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:28:20.079 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:28:21.141 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:30:28.954 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:30:30.016 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:32:37.985 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:32:39.048 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:34:47.110 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:34:48.173 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:36:56.235 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:36:57.282 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:36:57.313 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:39:55.407 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:39:56.438 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'HMIP' on gateway 'ccu2' not available, disabling support
2018-02-26 20:39:57.470 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:39:58.485 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'GROUP' on gateway 'ccu2' not available, disabling support
2018-02-26 20:39:58.485 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=false,cuxd=false,group=false]
2018-02-26 20:42:06.360 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:42:15.360 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:42:16.376 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'GROUP' on gateway 'ccu2' not available, disabling support
2018-02-26 20:42:16.376 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=false]
2018-02-26 20:44:25.235 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:44:26.345 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:44:34.391 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:46:42.079 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:46:43.188 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:46:43.298 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:48:50.751 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:48:51.829 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:48:51.923 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:50:59.454 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:51:00.595 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:51:00.688 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:53:08.313 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:53:09.407 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:53:09.501 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:55:17.079 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:55:18.204 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:55:18.298 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:57:26.157 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:57:27.282 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:57:27.376 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 20:59:34.907 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 20:59:36.001 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 20:59:36.079 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:01:43.688 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:01:44.766 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:01:44.845 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:03:52.391 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:03:53.501 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:03:53.657 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:06:01.282 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:06:02.391 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:06:02.454 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:08:09.970 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:08:11.048 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:08:11.173 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:10:18.891 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:10:19.970 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:10:20.048 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:12:27.923 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:12:29.016 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:12:29.079 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:14:36.766 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:14:37.845 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:14:37.907 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:16:45.579 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:16:46.657 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:16:46.735 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:18:54.391 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:18:55.454 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:18:55.516 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:21:03.173 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:21:04.266 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:21:04.360 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:23:12.001 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:23:13.110 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:23:13.204 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:25:21.173 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:25:22.266 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:25:22.345 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:27:30.298 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:27:31.391 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:27:31.454 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:29:39.157 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:29:40.266 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:29:40.345 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:31:48.001 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:31:49.110 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:31:49.157 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:33:56.641 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:33:57.735 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:33:57.798 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:36:05.595 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:36:06.688 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:36:06.766 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:38:14.360 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:38:15.438 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:38:15.501 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:40:23.173 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:40:24.282 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:40:24.360 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:42:31.876 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:42:32.954 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:42:33.016 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:44:40.766 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:44:41.860 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:44:41.938 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:46:49.563 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:46:50.641 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:46:50.735 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:48:58.282 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:48:59.532 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:48:59.610 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:51:07.548 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:51:08.641 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:51:08.735 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:53:15.726 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:53:16.820 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:53:16.930 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
2018-02-26 21:53:24.199 [WARN ] [ome.core.thing.internal.ThingManager] - Disposing handler for thing 'homematic:bridge:ccu2' takes more than 5000ms.
2018-02-26 21:55:39.359 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'ccu2' not available, disabling support
2018-02-26 21:55:40.437 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu2' not available, disabling support
2018-02-26 21:55:40.500 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.31.25,address=MEQ0775063,wired=false,hmip=true,cuxd=false,group=true]
Were you able to solve the issue? I’m having the same problem. It worked well on a previous installation of OH (I believe it was 2.2 or 2.3) but with the current 2.4 I have no success getting the bridge thing into online mode (first initializing, then offline communication problem).
