Hello all,
i updated my Homematic CCU 1 to 2.21.10 and it seems that openhab can’t connect anymore to the CCU now.
PaperUI says its Offline with following message:: java.nio.channels.UnresolvedAddressException
Before the update it works properly.
System:
Linux Debian 8 und Windows 7
Last openhab2 release.
Log Output:
2016-10-07 11:35:15.977 [INFO ] [ternal.communicator.HomematicGateway] - Interface 'WIRED' on gateway '7694ac7e' not available, disabling support
2016-10-07 11:35:15.978 [INFO ] [ternal.communicator.HomematicGateway] - Interface 'CUXD' on gateway '7694ac7e' not available, disabling support
2016-10-07 11:35:15.979 [INFO ] [ternal.communicator.HomematicGateway] - Interface 'HMIP' on gateway '7694ac7e' not available, disabling support
2016-10-07 11:35:15.979 [INFO ] [ternal.communicator.HomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.21.10,address=KEQ0383914]
2016-10-07 11:35:19.598 [INFO ] [ternal.communicator.HomematicGateway] - Interface 'WIRED' on gateway '7694ac7e' not available, disabling support
2016-10-07 11:35:19.599 [INFO ] [ternal.communicator.HomematicGateway] - Interface 'CUXD' on gateway '7694ac7e' not available, disabling support
2016-10-07 11:35:19.600 [INFO ] [ternal.communicator.HomematicGateway] - Interface 'HMIP' on gateway '7694ac7e' not available, disabling support
2016-10-07 11:35:19.601 [INFO ] [ternal.communicator.HomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.21.10,address=KEQ0383914]
2016-10-07 11:35:25.196 [INFO ] [ternal.communicator.HomematicGateway] - Interface 'WIRED' on gateway '7694ac7e' not available, disabling support
2016-10-07 11:35:25.197 [INFO ] [ternal.communicator.HomematicGateway] - Interface 'CUXD' on gateway '7694ac7e' not available, disabling support
2016-10-07 11:35:25.198 [INFO ] [ternal.communicator.HomematicGateway] - Interface 'HMIP' on gateway '7694ac7e' not available, disabling support
2016-10-07 11:35:25.198 [INFO ] [ternal.communicator.HomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.21.10,address=KEQ0383914]
