hometic binding says:
New in 1.9 (with this pull request)
HomematicIP support.
HomematicIP is disabled by default, because if you don't have HM-IP devices, the binding still communicates with BIN-RPC. If you enable HM-IP support, the binding uses XML-RPC. Configuration in openhab.cfg:
homematic:homematicIP.enabled=true
But where can I configure this in OH2? There is no openhab.cfg and in PaperUI I cannot find a seeting to cotnrol homematicIP device support.
